do I need reverse
do I need reverse
Home › Forums › General Questions › do I need reverse
  • #185847
    kevin large
      @kevinlarge76611
      I have a warco 220 at some point its had anew motor fitted and not been wired up properly if I cut threads do I need the reverse or is it OK to move the tool back manually I've had a couple of people look at the wiring but don't seem to fathem how it should work .
      #23805
      kevin large
        @kevinlarge76611
        #185850
        Capstan Speaking
          @capstanspeaking95294
          In a word . . . maybe wink
          It depends on the pitch being cut and whether you have an indicator dial.
          Do you have a manual?
          #185859
          jann west
            @jannwest71382
            reverse makes thread cutting a hellofalot easier
            … also unwinding your tie when it gets caught in your workpiece
            #185866
            Chris Hembry
              @chrishembry84309
              Hi Kevin,
              In short, yes you do. Warco 220s do not have an indicator dial as the leadscrew is permanently engaged on the carriage handwheel. For all threading, the lathe must be reversed to run back. If the engagement lever is lifted, you stand no chance of picking up the thread again.
              I have the wiring diagram for the lathe and it is fairly simple to arrange the motor to run in reverse if it is the same type as the original.
              Regards, Chris
              #185869
              Bob Brown 1
                @bobbrown1
                It is also possible to turn the chuck backwards by hand, needs must when the devil drives.
                Bob
                #185877
                Les Jones 1
                  @lesjones1
                  Hi Kevin,
                  If you gave some indication of your approximate location in your profile there may be somone close enough and willing to offer to help sort out your problem. The fact that Chris has the wiring diagram should make it easier to sort out.
                  Are there 4 wires (Plus an earth wire) going to the motor but only two connected ? Also is there still a reversing switch on the lathe ?
                  Les.
                  Edited By Les Jones 1 on 08/04/2015 22:37:25
                  #185884
                  kevin large
                    @kevinlarge76611
                    Hi I don't know if the motor is the same as original but its a 3 phase wired as a single phase it has 2 capacitators its been wired as is shown in the lid and uses 2 bridges
                    2 of the wires from the motor have been cut off I have a diagram from a CD but not sure if its applicable to my machine and it doesn't show what wire is what and what goes to z1 z2 etc or where the caps connect
                    Oh it does have the panic button but no red and green button in box on the end and no micro switches it looks like 4 wires and earth coming from the forward and reverse switch
                    Chris if you could email your wiring diagram I could see if it makes sense to me
                    #185887
                    Les Jones 1
                      @lesjones1
                      Hi Kevin,
                      Are you sure it is a 3 phase motor ? I do not beleive a 3 phase motor would have a diagram on the lid of the connection box showing how to connect it to use it from single phase. Pictures of the motor connection box, the diagram on the lid and the plate on the motor showing the ratings would help us understand the situation. I think you will need the help of someone with electrical knowlege on site to help you. Chris will need your email address to be able to send you the diagram. I would not advise you to post it on the forum. Send Chris a PM with it. Chris's diagram will not show how to mahe a 3 phase motor work from a single phase supply. If it is really a 3 phase motor and has the option of connecting it in both star and delta configuration I think fitting a VFD would be a better option.
                      Les.
                      #185895
                      kevin large
                        @kevinlarge76611
                        Hi les I am only going by what I was told about the motor the plate is very difficult to see its on the inside I will try and see what it says
                        kevin
                        #185898
                        Nicholas Farr
                          @nicholasfarr14254
                          Hi Kevin, there is a wiring diagram for both single phase and three phase, both should have a contactor box with a start and stop button. This box should be connected in line with the forward/reverse lever. The contactor box is a NVR which will stop the lathe from restarting automatically in the event of a power failure, it can be seen in the scan below, attached to the right hand end of the splash back.
                          Warco 220
                          I have a PDF of the user manual with both circuits in, if you would like a copy PM me with an e-mail address.
                          Regards Nick.
                          #185902
                          Ian S C
                            @iansc
                            I think you'll find it's single phase, 110V/230V. My Taiwanese lathe is wired this way as a dual voltage motor, and the circuit diagram Is on the LH end of the bed, it also has the diagram of the 3 phase option.
                            Ian S C
