spindle bearings
spindle bearings
Home › Forums › General Questions › spindle bearings
Viewing 25 posts - 1 through 25 (of 37 total)
  • #132563
    Kevin Bennett
      @kevinbennett25223
      hi my spindle bearings are shot in my Chester Champion Mill the Chinese bearings have lasted 12 years the question is do I fit like for like, the angular bearings 30x55x13.
      or do I modify the spindle and fit taper bearings 30x55x17
      any suggestion please
      ty Kevin
      #22891
      Kevin Bennett
        @kevinbennett25223
        #132565
        John Rudd
          @johnrudd16576
          I fitted tapers to my Chester Conquest when I went to a belt drive……..
          #132571
          Kevin Bennett
            @kevinbennett25223
            hi John did you have to modify the spindle for the extra 4mm taken up with the taper bearings
            #132585
            John Rudd
              @johnrudd16576
              Kevin,
              the only mod I had to make was ensure the inner races were a tight sliding fit on the spindle to ensure that they could be preloaded.
              #132598
              John McNamara
                @johnmcnamara74883
                Hi Kevin
                If you do a lot of high speed machining angular contact bearings will run cooler. They are pretty much the "standard" bearing for machining centre spindles. If you do use taper roller bearings check the maximum speed rating for the bearing you select to make sure it is within spec.
                The twelve years you got from the Chinese angular contact bearings was a pretty good run. They clearly were able to cope with the loads you imposed on them.
                Lubrication is important! Don't be tempted to use plain old automotive wheel bearing grease. Get the manufacturer recommended lubricant for your selected bearings, you may need to sit down when they tell you the price. Maybe you can share the cost with a mate.
                Kevin Bennett
                  @kevinbennett25223
                  John that for that I will keep it standard as it has lasted this long all the best
                  kevin
                  #132918
                  Kevin Bennett
                    @kevinbennett25223
                    OMG I have just jot the cost for my 2 off mill bearings, when I picked myself up from the floor what a rip off from a UK supplier Part No: 7006 Single Row Angular Contact Bearing Brand: NTN or equivalent Quantity: 2 Price each: £75.50 total £151.00.
                    I called Chester machine tools with no luck all they said was we do not stock or sell them is this the case for Chinese machines'
                    looked at most UK bearings suppliers and on eBay in the UK they do not stock the size 30x55x13 the US & China have them but are as good as they look
                    as for my first post do I change to tapper bearing to keep the cost down
                    thanks Kevin
                    #132921
                    Richard Marks
                      @richardmarks80868
                      Kevin
                      First thing to do is contact Arc Euro Trade and Keiran will help you to decide and will supply the correct bearings,
                      I have no association with them but have always got good advice and good prices.
                      Dick
                      #132922
                      jason udall
                        @jasonudall57142
                        When you see the price of bearings you might have doubt about the ones ” built in” in first place
                        #132923
                        mgnbuk
                          @mgnbuk
                          Under £30 each here – and they are precision bearings as well
                          HTH
                          Edited By Nigel Barraclough on 17/10/2013 18:12:15
                          #132924
                          John Rudd
                            @johnrudd16576
                            I paid £20 for a pair of quality bearings from a local bearing supplier when I changed them…..Best bet is Arc…..usual disclaimer…. Just a happy bunny
                            #132929
                            Kevin Bennett
                              @kevinbennett25223
                              hi Nigel the Bearing boys are not Single Row Angular Contact Bearing I have looked and researched it
                              thanks Kev
                              #132930
                              mgnbuk
                                @mgnbuk
                                7006-CSUP4 Precision Ball Bearing Single 30mm x 55mm x 13mm
                                • Precision grade – P4
                                • 15 degree contact angle
                                • Single bearing
                                Only one type of 7006 single row angular contact bearing –
                                in your position, that is the one I would be ordering.
                                Edited By Nigel Barraclough on 17/10/2013 19:36:09
                                #132931
                                Ketan Swali
                                  @ketanswali79440
                                  Kevin,
                                  Funny enough, I will be needing to order one of these for myself.
                                  There are two+ grades. The ones in your mill are standard and not high precision. I will be needing the high precision 7006 for my KX3 mill in our workshop because of CNC higher speed requirement, but still not super high precision.
                                  If you want, give me a call in the morning. I will check for you when I am ordering mine. Also, stick with the angular contact ball bearing. The choice is yours standard or high precision. In your mills case, no special grease necessary. Just don't overload it with the grease.
                                  Ketan at ARC.
                                  #132934
                                  Richard Marks
                                    @richardmarks80868
                                    Ketan
                                    Sorry meant Ketan not Keiran, age you know!
                                    Dick
                                    #132935
                                    Kevin Bennett
                                      @kevinbennett25223
                                      thanks for that I have already sent a pm to Ketan
                                      TY Kevin
                                      #132939
                                      John McNamara
                                        @johnmcnamara74883
                                        Hi Keven
                                        VXB Bearings (US) list them for about $14.00 Standard grade
                                        They will also supply high spec if required
                                        I do wonder about using super precision bearings on a conventional mill? OK if you have a temperature controlled high spec mill. that will no doubt be fitted with a cartridge spindle that has been fitted with high spec bearings and then the taper ground in situe before being tested for run out, greased up and certified.
                                        The difference between super precision and commercial grade bearings is only a tenth or two these days, the main thing as mentioned before is that the speed and load rating for the particular bearing chosen is appropriate.
                                        Maybe the cost premium for super precision could be better spent elsewhere?
                                        The will ship anywhere….
                                        I have no connection to them
                                        Edited By John McNamara on 18/10/2013 00:02:43
                                        #414335
                                        Michael Horner
                                          @michaelhorner54327
                                          Hi Kevin
                                          How did you get on with your bearing replacement?
                                          I am in a similar position with my KX3, it took a hard dive into the job and took out the bearings.
                                          Cheers Michael
                                          #414337
                                          RMA
                                            @rma
                                            Interesting debate here. When you say they have lasted for 12 year's, how much work have they actually done in that time, and at what sort of loads? I'm a firm believer in taper roller bearings, you can preload and adjust, but these day's quality doesn't come cheap. However, if you use the machine a lot then the cost is well worth it. The machine is virtually useless if the spindle doesn't run true.
                                            #414360
                                            Ian S C
                                              @iansc
                                              Just follow Ketan's advice, he knows bearings.
                                              Ian S C
                                              #414361
                                                And use the bearing manufacturer’s advice on lubrication – not the machine supplier. The latter would likely be inferior and more expensive! (I did note the supplier was not Arc, before making that comment)
                                                #414363
                                                RMA
                                                  @rma
                                                  Posted by Ian S C on 15/06/2019 12:25:40:
                                                  Ian S C
                                                  I'm sure he does, like a lot of people. I served my time as an apprentice with the Timken Tapered Roller Bearing company so I'm a little bit biased. Sadly the company moved out of England and relocated in India. I'm not familiar with this machine, so I don't know what would be involved in changing the bearing arrangement.
                                                  With bearings, like a lot of things, you only get what you pay for. In the case of the hobbyist, and if the machine will be idle most of the time, it might be better to go cheaper, just depends how much and what type of work the machine will be doing in the future.
                                                  #414364
                                                  RMA
                                                    @rma
                                                    Posted by not done it yet on 15/06/2019 12:34:49:
                                                    Definitely!
                                                    #414366
                                                    larry phelan 1
                                                      @larryphelan1
                                                      Surprised that Chester did not stock bearings for the machine they sold you.
