Brazing Stainless steel superheater return
Home Forums General Questions Brazing Stainless steel superheater return
  • #22453
    John Hyde 1
      @johnhyde1
      #110813
      John Hyde 1
        @johnhyde1
        Any tips please on brazing the above? Return comprises 2 x 5/16" dia. thin wall stainless tubes into a stainless return block. What braze rod and flux should I use?
        #111441
        John Hyde 1
          @johnhyde1
          Should any one out there be interested, the answer is weld it,which has now been done.
          #111445
          Springbok
            @springbok
            Have a word with CupAlloys they will steer you in the correct path
            Bob
            #111452
            CuP Alloys
              @cupalloys
              Hello John
              First consideration is to use an austenitic stainless steel to prevent any corrosion of the joint in a damp or wet environment. These are the 300 series.
              If you are not sure, use a magnet. Austenitic stainless is non-magnetic
              Then use a flux suitable for capable of removing chromium oxide eg HT5
              Nothing to choose between the silver solders other than meltng temperature. You pays your money and makes your choice.
              regards
              keith
              PS If your stainless is magnetic you must use a silver solder that contains nickel to prevent that corrosion. Use 449 alloy but it is not as easy to use as say 455 or 438. Easier to use 300 series stainless – readily available from your usual source of tube.
              #111459
              Steambuff
                @steambuff
                Since the Superheater tube and return block are often situated in the top of the firebox, should the joint be welded and not siver-soldered?
                Will the Silver-Solder Melt?
                Russell Eberhardt
                  @russelleberhardt48058
                  I would have thought that while there is reasonable steam flow it would be OK but as soon as the engine is stopped you would have a problem.
                  Russell
                  #111474
                  Steambuff
                    @steambuff
                    Russell,
                    True under low speed/load … bu if the loco is working very hard, the fire is going to get even hotter .. white hot even …
                    So I think silver soldering is a no-no. (The reason Stainless steel is used is to eliminate the risk of copper melting.
                    If the Super-heater does not enter the fire-box then you might just be ok …. not a risk I would take though.
                    John Baguley
                      @johnbaguley78655
                      I've always used Silverflo24 for the return bends on stainless superheaters and haven't had a problem yet. I make sure the return block is at the back of the firebox above the firehole where the temperatures are less extreme but the elements can and do glow red at times.
                      John Hyde 1
                        @johnhyde1
                        Thankyou everybody for your responses. I think its established therefore that silver soldering the unit is perfectly OK. But its working life in the firebox at sometimes very high temperatures, makes it too much of a risk for me to take. So the unit has been welded to give peace of mind………..but I had to cough up some cash to get it done, much against my principles!!!
                        John H
