Drawings for Stuart No. 9 governor.
Home › Forums › General Questions › Drawings for Stuart No. 9 governor.
  • #22381
    The Merry Miller
      @themerrymiller
      #106952
      The Merry Miller
        @themerrymiller
        Has anybody out there built the above governor?
        I have aquired a set of castings from my club's end of year "bring and buy sale" At least I think it maybe a set but without the drawings I can't confirm this.
        If a kind person who has built it can advise me on the correct number of castings I would appreciate it, better still if there is a set drawings available for sale or something.
        I tried contacting Stuart Models but they are on a Christmas break now until the New Year and I would like to start preparing the ground for machining etc. before they return.
        Len. P.
        #106966
        Colin Abrey
          @colinabrey20074
          Len,
          I have a copy of the drawings and will scan them for you. Send me an e-mail and I will send you the copies.
          [email protected]
          Colin
          #106970
          NJH
            @njh
            Hi Len
            i've sent you a pm.
            Cheers
            Norman
            Edited By NJH on 22/12/2012 16:51:31
            #107017
            Ian S C
              @iansc
              Hi Len, the S9 that I rebuilt is in the stationary engines section, and my album. I had most of the bits, but had to make the balls and arms, and after a few runs the top of the governor shaft broke off just under the adjusting nut, so that's been replaced with a bit of the threaded end of a bike spoke(did'nt have a die to make the 7ba thread on the origional shaft. Had to make the linkage, and the butterfly for the governor.
              If you get things adjusted just right, it works quite well. Ian S C
              ps:  the newer ones don't seem to have the governor, which is a pity.
              Edited By Ian S C on 23/12/2012 00:44:36
              #107043
              The Merry Miller
                @themerrymiller
                Colin and Norman,
                Thanks for your collective inputs. Norman's Tubal Cain version is the one that uses most of the castings that I have aquired with the exception of the main top section that holds the weights, that's missing.I'll have to machine that from solid.
                Colin's version appears to be the later one from Stuart Models that minimises the use of castings but like Ian's I will finish up with a hybrid of home made bits, It's going to be fitted to an S50 eventually.
                Ian, I'll study your version in a bit more detail later but it looks good.
                Thanks again lads and Seasons Greetings to you and to all my readers!!
                P.S.
                I've ordered the Tubal Cain book on building the Stuart No. 9 from Waterstones (on line) for £6.26 plus free delivery. Amazon had no stock..
                I think I'll look at Waterstones again in the future, makes a change from Amazon.
                Len. P.
