Milling Cutter sharpening
Home › Forums › General Questions › Milling Cutter sharpening
  • #21985
    Paul Scholey
      @paulscholey17560
      #80783
      Paul Scholey
        @paulscholey17560
        I recently had a milling cutter priced for sharpening locally and it was £18 plus vat. It is 125ml long but it seems a lot?
        I was just wondering if there is anywhere mail order?
        #80784
        michael howarth 1
          @michaelhowarth1
          Paul….there is a gentleman called Geoff Josey who advertises on the Home Workshop site who sharpens end mills and slot drills. Not only does he do a fantastic job of them but he charges an unbelievable £1 each plus postage….he will ask you to make the cheque payable to a hospice. Thoroughly recommended and very speedy service from a true gentleman……..which reminds me, I must send off another batch to him.
          His email address is ……… [email protected]
          Mick
          #80785
          Martin Walsh 1
            @martinwalsh1
            there is ABBCO they are tool and cutter grinding specilists
            funnily enough they are right next door to the old myford factory
            in beeston nottingham
            their number is 0115 9226060
            hope this helps
            Best Wishes Martin
            #80786
            Paul Scholey
              @paulscholey17560
              Thanks for the replies, I’m going to check the £1 out first.
              #80807
              Paul Scholey
                @paulscholey17560
                I’ve found the add for Goeff Josey and he sharpens cutters up to a maximum of 16mm unfortunately mine is 3/4 with a 5/8 shank.
                #80808
                David Clark 13
                  @davidclark13
                  Hi There
                  5/8 is less than 16mm.
                  Perhaps he is limited to shank size so he could do it.
                  regards David
                  #80809
                  Paul Scholey
                    @paulscholey17560
                    I’ve sent him an e-mail David. I’m hoping he goes on shank size rather than cutter size.
                    #80923
                    Paul Scholey
                      @paulscholey17560
                      I’ve been in touch with Geoff Josey and he only sharpens the ends.
                      #80997
                      Paul Scholey
                        @paulscholey17560
                        I will send it to abbcotooling it will still be half the price even with postage.
                        Thanks Martin.
                        #81039
                        Jim Greethead
                          @jimgreethead
                          Does anybody know of a similar sharpening service on the east coast of Australia?
                          Jim
                          #299854
                          mechman48
                            @mechman48
                            Posted by mick H on 29/12/2011 16:53:58:
                            Mick.
                            ​I've just received back today 10 HSS cutters that Geoff has re-sharpened for me this week from 1/4" -3/8" & 6mm – 16mm. I can say what a fine job he has done & quickly too. He still does cutter sharpening to this day & as for cost … extremely cost effective…£16 for 10 cutters. I sent a PO for the amount made out to himself & he made out a check to his hospice choice, or as above, a cheque made out to the charity. I can thoroughly recommend his service should anyone need cutters sharpening, just e- mail him at … [email protected]
                            George.
                            #299877
                            John Reese
                              @johnreese12848
                              I have the equipment to properly grind both the ends and flutes of end mills. Unfortunately I am in the US so it is impractical for me to offer services. Were I closer to you I would propose a mill sharpening party where you bring your cutters plus pizza and beer. Maybe you can find a member in the UK that is properly equipped and willing to do a similar thing.
                              I think you will find the industrial sharpening services expensive unless you have a large number of identical mills to sharpen.
                              #300228
                              David Paterson 4
                                @davidpaterson4
                                Posted by Jim Greethead on 02/01/2012 08:50:48:
                                Jim
                                Try these guys
                                they are local to me and I use them for bandsaw blades and router bits, haven't tried milling cutters but good service to me.
                                cheers
                                #300247
                                D Hanna
                                  @dhanna35823
                                  Jim
                                  The east coast of OZ is quite a distance Jim! Where are you located?
