Siemens Solid Edge and VRED
Home › Forums › CAD – Technical drawing & design › Siemens Solid Edge and VRED
  • #21282
    Raymond Anderson
      @raymondanderson34407
      Autodesk VRED
      #404032
      Raymond Anderson
        new texture map on c to b.42.jpgtailstock die holder.jpgnew render for cto b .jpgBeen trying to get to grips with the above software Very powerful. I have Keyshot.. but this is a few notches above that. The pics are only of my "playing around " The 3d models were done in Siemens SolidEdge Wondered if any forum members have used VRED. Steep learning curve dont knowcolumn to beam grey primer.24.jpg
        #404059
        John Reese
          @johnreese12848
          I started with Solid Edge. Pretty easy to learn. Later I switched to Solid Works. The user interface is quite similar between the two. I had a little experience with Autodesk Inventor. The user interface was a little different. I tried to use Fusion 360 but the workflow was sufficiently different that I decided to stay with Solid Works. If I didn't own a license for Solid Works I would probably pick Solid Edge.
          #404066
          Raymond Anderson
            Hi John, although I'm fully conversant with Solidedge. I'm just starting out with VRed rendering software. I hope practice makes perfect 😂
