Myford quick change gearbox quadrant pinch bolt access
Home Forums Workshop Tools and Tooling Myford quick change gearbox quadrant pinch bolt access
Viewing 2 posts - 1 through 2 (of 2 total)
  • #19015
    C J
      @cj88518
      #364739
      C J
        @cj88518
        I have been cutting some metric threads recently by swapping 33 and 34 teeth input gears but today I finally caved in struggling to undo and tighten the quadrant pinch bolt without removing the bull gear and drilled a 9mm hole in the casing for access the bolt with an Allen key on end, and when not in use put a car wheel cylinder bung in the hole.
        Sacrilege perhaps but it works for me.
