Mystery Tool- What is it?
Home › Forums › Workshop Tools and Tooling › Mystery Tool- What is it?
  • #212548
    Grotto
      @grotto
      dsc07046.jpgdsc07045.jpgdsc07044.jpgI bought this awhile ago, partly because the dial gauge is more accurarate than my other, but mainly because I liked the look of it.
      Looks like it has a specific use, and wondered if anyone knows what that is?
      #17897
      Grotto
        @grotto
        #212550
        Phil P
          @philp
          I wonder if it is for adjusting a "Microbore" tip in a boring bar ?
          Phil
          #212553
          Jim C
            @jimc
            It could be used to check for roundness / lobing or concentric it's of one diameter to another ?
            #212554
            Jim C
              @jimc
              Sorry that should have been concentricity of one dia. to another.
              #212558
                Posted by Phil P on 16/11/2015 07:21:19:
                Phil
                Agreed … I have something similar, but fitted with a micrometer thimble.
                john carruthers
                  @johncarruthers46255
                  I made something similar to centre the worm gear on a hub in an Alter D6 mount.
                  #212561
                  Emgee
                    @emgee
                    Another use could be to measure the height of a keyway fitted key above the OD of a shaft.
                    Emgee
                    #212563
                    Harold Hall 1
                      @haroldhall1
                      Used on a surface plate in an inspection department for checking a dimension on a number of identical parts, note the small lever on the top for raising the plunger making it easy to place the component for checking.
                      Harold
                      #212565
                      Ajohnw
                        @ajohnw51620
                        There is a stop in the V block formed by the base so it could be used to check a dimension off a round or square bar with some shape on the end.
                        It will also sit flat on a surface plate so could be used for checking thickness and it just happens to have the V block type facility. I'd guess that is most likely.
                        Clive Hartland
                          @clivehartland94829
                          From the marks on the faces of the 'V' it has been used on round items. From this I would think it is used to measure depth of keyways/steps on a round body.
                          #212588
                          mechman48
                            @mechman48
                            Comparator from an inspection department to check batch samples, lift plunger with lever, place sample under plunger & check dimension ?
                            George.
                            #212601
                            colin hawes
                              @colinhawes85982
                              This is a comparator set up. Usually set up with slip gauges to compare the job being measured against the slips. Where possible It should be adjusted so that the plunger does not need to be lifted each time but the job slid under and through to give a wiping action to ensure no dust build-up on the plunger. The measuring anvil would have a spherical end to facilitate this Colin
                              #212608
                              Ajohnw
                                @ajohnw51620
                                Posted by Clive Hartland on 16/11/2015 09:55:07:
                                The "stop" in the V could match the keyway width so that is probably the best answer yet.
