Myford Super 7 Metric thread cutting gears
Home › Forums › Manual machine tools › Myford Super 7 Metric thread cutting gears
Viewing 25 posts - 1 through 25 (of 39 total)
  • #438500
    Jesper Crone
      @jespercrone20634
      Dear members
      40 years has gone since my education as a fine mechanical engineer and also 40 years away from machining I just bought a Myford Super 7 anno 1955-56 (2 years older than me) for making various bits and pieces. First job was to make a nut with an internal thread M62x1,25 for my Arboga Milling machine. Made in Stainless steel all turning and slotting went very well but the pitch wasn't accurate
      The super 7 is delivered i July 1956 to Greenland, Serialno SK 4986 with gearbox serialno QC 1942. I just have the fitted gears
      From spindle: 30, 30 and 28 fibre, 30T/12T, 57T/19T, 57T/19T, 72T(on the gearbox)
      Main priority is metric threads but I also need some inch cutting.
      I'm obviously are missing some gears; have read in here about a 33T and 34T but assume it won't fit my machine – or if – where to fit and where to get them
      I hope for some useful help – all the best from Jesper in Denmark
      I didn't figure out how to insert picture
      #13707
      Jesper Crone
        @jespercrone20634
        #438519
        DC31k
          @dc31k
          Until someone more qualified comes along, please have a look here:
          https://www.model-engineer.co.uk/forums/postings.asp?th=125630
          as I think it will answer most questions.
          #438521
          David George 1
            @davidgeorge1
            Hi Jesper welcome to the forum. I don't know about your Myford but on my Drummond I have a list which tells you the change gears on the headstock and you should be able to change the gears to cut metric threads with no problem if you have the gears in the list. They are available to buy either second hand or new.
            If you search on this site put in screw cutting metric threads in the small box at the top of this page, keyword, it will come up with lots of information and pictures already listed as this question has come up before also i am sure more knowable will post soon.
            David
            #438530
            Simon Williams 3
              @simonwilliams3
              Good morning Jesper, hopefully Brian Wood will chip in shortly, can I suggest you need a copy of his book "Gearing of Lathes for Screwcutting" which covers this in detail and answers the questions you are asking. Copies usually available from Arc Euro and also Amazon.
              Essentially you need the magic gears, but I suspect from the date you have the early version of the quick cutting gearbox, the difference is a 2:1 reduction in the later box which means for you that you need a 17 and a 16-1/2 tooth gear on the mandrel to cut accurate metric threads, not the 34 and 33 tooth gears. If you can work out how to post a picture of the right hand side of the gearbox we can determine which gear box you have, and hence which gears are needed.
              [Edit:  the 30/12 cluster gear in the gear train you have described in your initial post confirms that we're dealing with the older style gearbox.]
              The 16-1/2 tooth gear sounds mighty odd, but don't worry all will be explained. You might like to do a bit of back ground reading on the subject here:
              QCGB1 should take you there
              Also:
              https://www.model-engineer.co.uk/forums/postings.asp?th=131985
              QCGB2 links to it.
              To post a picture you have to upload a JPG to a site album first, then reference it in your post. So , log in, go to Albums on the header and start a new album giving it a suitable name. Now up load your picture in jpg format, it helps if the file size is sensible but I think I've read that the forum software sizes the file anyway if needs be. Now you can write a forum message, and include your picture by using the little camera icon in the message header. This opens a screen where you browse to the picture you want to include in the album you just started, and then pastes it into your message for the rest of us to see. Hope that makes sense. and if I've missed anything out please could those with more knowledge correct my summary.
              Hope that helps, this is a subject with plenty of reference stuff on the forum, so I'm sure we can sort out the problem you have encountered.
              Best rgds Simon
              Edited By Simon Williams 3 on 24/11/2019 09:42:53
              #438534
                It does to me, too.
                Can you explain what a gear is with half a tooth, please. I’ve seen some quite often but they were in need of repair!
                #438543
                Simon Williams 3
                  @simonwilliams3
                  NDIY –
                  The explanation is in the two threads I have referenced.
                  No, I haven't worked out how to make a half tooth – well not intentionally anyway. The key to this is that the gear cluster is either a 17 : 30 or alternatively 16-1/2 : 30. as a compound pair. You need both sets to achieve the whole range of standard metric pitches for the sort of sizes a Myford owner might encounter.
                  16-1/2.: 30 is almost exactly 16 : 29, so that's what I made. John Stevenson worked out for me how to make a 29 tooth gear on a 30 T blank so it would mesh correctly with the tumbler gears. Details are in the two threads referenced above.
                  Works a treat, and I'm fairly certain that's what Jesper needs to solve the pitch error problem he has encountered.
                  Rgds Simon
                  #438544
                  Lambton
                    @lambton
                    Jesper,
                    The first thing that you should do is get a proper Myford handbook for your model of lathe. Obtainable to buy from Myford **LINK**
                    PDFs of the handbook can be down loaded free from the net.
                    It is difficult to cut metric threads on a gearbox fitted Super 7 without having the correct gears and A2469 quadrant. However no lathe with an imperial lead screw can ever cut true metric threads unless a 127 change wheel is used in the gear train.
                    33 and 34 tooth gears can be used by fitting either in place of the 24 tooth driver gear from the tumbler reverse output and then selecting the appropriate gear box TPI setting (see chart which includes other gears that provide the most accurate metric threads possible Separate post.
                    Eric
                    m
                    #438545
                    Lambton
                      @lambton
                      Jasper I have sent you a personal message Please look at green INBOX button the top of the page which should be flashing
                      .Eric
                      #438548
                      Brian Wood
                        @brianwood45127
                        Simon and Jesper,
                        Simon and I had a lot of correspondence on this topic some time ago and the trouble he had applying my book methods to his lathe with the early gearbox. You will recognise one by the small additional housing on the carriage side into which the leadscrew goes.
                        I can't add anything useful to what Simon says so read the story that he has given you links to, it will get you past the difficulties you are having and into the promised land! The results you will get will still be approximations, but they are more than close enough for the sort of work we do. Lambton is quite correct in saying that true values need a final change wheel of 127 teeth in the chain but it is a wheel of very nearly 6.5 inches in diameter. The lathe needs raising blocks to get it clear of the bench, or positioning so that it can run in fresh air over the end of the bench.
                        Never mind the cost of buying it either!
                        Brian
                        #438550
                          Posted by Brian Wood on 24/11/2019 10:53:38:
                          […] Lambton is quite correct in saying that true values need a final change wheel of 127 teeth in the chain but it is a wheel of very nearly 6.5 inches in diameter. The lathe needs raising blocks to get it clear of the bench, or positioning so that it can run in fresh air over the end of the bench.
                          … or perhaps you could follow the example of Martin Cleeve, and use a reduced pitch for the conversion gears:
                          Simon Williams 3
                            @simonwilliams3
                            MichaelG – thanks for your contribution, that's a very neat solution to the problem. However one of the main advantages to using substitute gears on the mandrel and retaining the other (standard) gears taking the drive to the gearbox input gear is to retain the availability of the fine feed function.
                            Brian and I examined the pitch error introduced by using 17 and 16-1/2 tooth gears, I'm happy the error is insignificant and within the normal working tolerances of the single point screw cutting technique.  There is a summary table in one of the threads referenced which lists the theoretical error.
                            There's nothing not to like, apart from the intricacies of making these compound gear sets.
                            HTH Simon
                            Edited By Simon Williams 3 on 24/11/2019 13:07:45
                            #438560
                              Posted by Simon Williams 3 on 24/11/2019 13:06:23:
                              Understood and accepted, Simon … Yours is clearly the right approach for a gearboxed lathe.
                              Cleeve’s was just a regular ML7 [or at least that’s how it started life]
                              Jesper Crone
                                @jespercrone20634
                                Posted by Jesper Crone on 23/11/2019 22:33:25:
                                Dear members
                                From spindle: 30T, 30T and 28T fibre, 30T/12T, 57T/19T, 57T/19T, 72T(on the gearbox)
                                #438573
                                Simon Williams 3
                                  @simonwilliams3
                                  Ah ha!
                                  Hello again Jesper, and thanks for the pictures. You obviously sussed out how to load them!
                                  But…….
                                  The plot thickens! Because the label you show from the inside of the gear cover isn't the right one! That label belongs with the standard Myford metric banjo kit, which was marketed to go with the NEWER gearbox, not the one you and I have got. The 2:1 gear reduction factor has to be taken into account.
                                  So here is a picture of the label inside the cover of the gearbox I have.
                                  If you have followed the links I showed earlier you will have realised that this is irrelevant, as using the 17 or 16-1/2 compound input gears sidesteps this problem.
                                  HTH Simon
                                  #438604
                                  Roderick Jenkins
                                    @roderickjenkins93242
                                    My best guess is that the gearbox is a later addition to the lathe, it certainly looks similar to the gearbox on my S7. If this is the case then the 33/34 T system will work.. The gears are available from RGD **LINK**
                                    This table shows the actual pitch of threads that can be made with this arrangement:
                                    Rod
                                    #438629
                                    Brian Wood
                                      @brianwood45127
                                      Hello Roderick,
                                      Jesper and Simon both have the early gearbox. It has a small outrigger housing on the carriage side of the gearbox with a pair of 18 T gears insideto make the leadscrew turn in a logical direction. I don't think your gearbox is of this pattern and therefore your table is valid for the later gearboxes
                                      Simon and John Stevenson worked out the fiddle gearing needed to get the early gearboxes to work, but as we have seen, the table installed in Jesper's lathe is not matched to the gearbox that is fitted to his lathe; in which case your table will not help him either I'm afraid.
                                      This is yet another combination of conditions brought about by incorrect matching of parts, possibly brought about by fitting the early gearbox to a bare lathe without appreciating the subtleties involved. .
                                      If Jesper could test his lathe using Simon's table, that should work. Whether he has the gears to do it I don't know
                                      Regards Brian
                                      #438666
                                      Jesper Crone
                                        @jespercrone20634
                                        Posted by Jesper Crone on 24/11/2019 13:58:47:
                                        Dear members
                                        Thank you very much for all your kind posts; I will get hold on the bible about gearing for screwcutting. I'm pretty sure that the gearbox was delivered with the machine in 1956 as I have both manuals; Lathe publ S.715 dated 56 and gearbox publ 712 dated 56 with the gearing chart as per pictures. BUT I have no extra gears than fitted on the pictures – so I'm much in doubt what I need to buy in order to cut metric screws – and I do not understand the 161/2 teeth gear nor where to buy.
                                        #438682
                                        Roderick Jenkins
                                          Hmm. Jesper's pictures seems to show a manual for the later type of gearbox as well as having the later plate in the cover. The 1680 gearbox is the same as retro-fitted to my S7. How can we determine which gearbox Jesper actually has?
                                          Rod
                                          Edit.  I've  just had a look at Tony's Lathes site and I see that 1956 was the year of change to the newer style gear  box.  Could Jesper's be some form of transitional box , old externals but new internals?
                                          Edited By Roderick Jenkins on 24/11/2019 23:25:16
                                          #438687
                                          peak4
                                            @peak4
                                            Posted by Roderick Jenkins on 24/11/2019 22:43:24:
                                            Rod
                                            Tony's site suggests that;
                                            but in 1956, from box QC 2495 onwards, important alterations were made – with a change to hardened gears and a leadscrew that was much better supported by being allowed to pass all the way through the box with the drive taken from its left-hand end – so allowing the external gears to be dispensed with.
                                            Since we know that Jesper's box has a serial no of QC1942, and photos also show the earlier version, with the little external gear cover on the right hand side, probably give the game away.
                                            Bill
                                            p.s. May I also recommend Faststone Image Viewer as a good program for basic image manipulation, including correcting orientation. devil
                                            Edited By peak4 on 25/11/2019 00:13:15
                                            #438774
                                            Simon Williams 3
                                              @simonwilliams3
                                              Jesper – good evening. Firstly my apologies for not picking up your questions sooner, I've been out of touch for a day.
                                              So, if I may I would like to summarise what we think we know, and answer your question about obtaining the requisite gear.
                                              I believe we have established that you have the older type QCGB, that's what the photo's of the lathe indicate, and the fact that you have a 30/12 cluster gear in the gear train on the mandrel gear suggests the same. What we don't know for absolutely certain is whether the lathe cuts the threads as indicated on the gearbox label. It's just possible that there is a mismatch here, and the gearbox cuts either twice or half the threads per inch that is indicated. This of course is when you are cutting an imperial thread such as 20TPI. The label inside the gear cover sows a seed of doubt in my mind, and I would just like to be sure we know where we are starting from before telling you what to do next. Can you try cutting a thread with the gearbox set up for (say) 20TPI – it needs only be a scratch pass to prove the gear train – and confirm that it is 20 TPI that you get.
                                              I chose 20 TPI because it is the same thing as 1.27 mm pitch – and if the M62 nut you were trying to make is only fairly short you may find that using a 20 TPI thread instead of 1.25 mm pitch gives acceptable results. After all the error is only 0,02 mm per revolution – so if your nut is 10 mm thick the thread error is still only +/- 0.08 mm.
                                              However, we can do better. ASSUMING the gearbox IS the old one, the gear train you have identified starts with a 30 tooth gear with a 12 tooth gear married to it to make a compound gear. This gives the thread per inch selection as per the label on top of the gearbox.
                                              If we change the 12 tooth gear for say 18 teeth we'll get a different set of TPI values for each position of the gearbox selector levers. In this example the gearbox output is speeded up by 50%, so our 20 TPI setting will now cut 13.3 (Edit – I got this wrong in my initial post – it's less TPI because the lead screw is running faster.  OOPS!)  TPI. Using other input gears gives us control over the threads on the workpiece over and above the "normal" (standard settings.
                                              One such choice is a 17 tooth gear. If we change the 12 tooth gear to be 17 teeth, and set the gearbox levers in the positions for 24TPI we get 16.94TPI, which equates to 1.499 mm pitch. The arithmetic is simple pro-rata gear ratios, but work it out in TPI and then convert to mm pitch last.
                                              So that's a nice accurate answer for 1.5 mm pitch. also 3mm, and 0.75 which is an oddity but it shows the principle. How do we go about getting 1.25 mm pitch.
                                              Do the same arithmetic, and you find you need a 16-1/2 tooth gear. Now whatever I've said before, I haven't worked out a way of making a single non whole number gear. But it isn't a single gear we're working with , it's a compound pair. The other gear of the compound pair was always 30 teeth, giving a 1 : 1 ratio with the chuck, but it doesn't have to be.
                                              16-1/2 : 30 is very close to 16 : 29, so if we change the input gear to be 29 teeth meshing with the tumbler gear, and now 16 teeth driving the otherwise standard gear train going down to the gearbox input we get jolly close to 1.25 pitch. And 2.5, also 0.625, another size we're likely never going to want!
                                              Enough for a moment, this post is long enough already, I'll continue in a second instalment.
                                              Edited By Simon Williams 3 on 25/11/2019 19:37:41
                                              #438779
                                              Simon Williams 3
                                                @simonwilliams3
                                                To continue my saga:-
                                                We've worked out how to play tunes on the gearbox output ratio to achieve a much wider variety of TPI or pitch settings that the original set by altering the input mandrel gear. It's only fair to say that this is the essence of Brian Wood's book, and far be it from me to steal his thunder.
                                                The difficulty we've created for ourselves is that the input (mandrel) gear for the MK1 S7 QCGB is this all in one double gear. The Mk 2 lathe has a demountable driver gear so (within reason) you can fit any standard change wheel to it and play even more tunes on the TPI chart.
                                                So the two compound gears I made were as follows Here is a picture of the standard 30/12 set on the left, and my 30/17 set on the right.
                                                xxxx
                                                I made it out of bronze because it is made in two parts – a 17 tooth gear cut on a stub shaft, then a 30 T wheel soft soldered onto the stub of the smaller gear. Besides , it looks pretty and I can recognise it easily in the drawer full of change wheels.
                                                So the same principle applies to the gear I christened the 16 -1/2 tooth gear, which was a bit of a joke between me and the late John Stevenson. I don't have a photo of it, but it looks exactly the same as the bronze one above except the small end is cut for 16 teeth, and the larger one is cut for 29 teeth, but on a blank of the same outside diameter as a 30 tooth gear. This ensures that it meshes correctly with the existing tumbler gears – there's no adjustment on the centre distance – but runs at the speed of a 29 tooth gear – it's only got 29 teeth so it runs a bit faster (as a driven gear the smaller it is the faster it runs).
                                                So far so good, but where do you buy one? Well, I only know one answer to that – simply there's the one in the picture in a drawer in my shed and I'll make a duplicate if you are interested. If so send me a PM and I'll explain further. I'm not too clear on the etiquette of touting for business openly on the forum – mod's please note I make no direct charge and all of the money goes to charity. It's such a specialist application I don't think anyone is making them commercially but if anyone with the technology fancies their chances be my guest. Indeed if Jesper knows anyone who can do this locally please have a go! Not sure if 3D printing technology is up to this, but some day someone will try it out.
                                                So I hope that answers the questions remaining, if not let me know what's not clear and I'll try and fill in the gaps.
                                                Good luck, and the arithmetic and more details are in the two threads referenced above.
                                                Ooh, and Brian's book goes into much more detail, with pictures and set-up tables and I recommend it.
                                                Best rgds Simon
                                                #438792
                                                Jesper Crone
                                                  @jespercrone20634
                                                  Hello Simon; Thank you for all your efforts.
                                                  I did follow your suggestion and made a thread with QC setting 20 TPI – and the pitch is 20 TPI; So far so good. then I just need a bunch of "metric teeth".
                                                  Jesper
                                                  #438823
                                                  Brian Wood
                                                    @brianwood45127
                                                    Hello again Simon and Jesper,
                                                    Until Simon had difficulties in trying to apply the information in my book, I had not appreciated that the earlier gearboxes were constructed as they are. It is only fitting therefore that Simon's work, so well supported as it was by John Stevenson, should take centre stage on the solutions he had made, tested and tabulated. He has done a first class job.
                                                    I would though just like to add a note of caution if machining thread pitches that are coarser than 0.125 inches [8 tpi]. The gearing in the Myford gearbox is only 10 mm wide, I am quoting here from memory but they are narrow, and the smallest tooth count gear within is 16 T of which there are three. The strain on teeth in that size, when pushing the gearbox hard, is very likely to bend soft teeth. This was I think the reason behind Myford switching to hardened components from gearbox Serial Number 2501 onwards while at the same time improving the design to carry the leadscrew through to reduction gearing on the change wheel side and dump the 12/30 gearing to replace it with 24/30 instead
                                                    And finally, as a little bit of mischief maybe, my fag packet calculations suggest another variant to solve the 16.5 tooth dilemma. A very similar degree of error as 16/29 is found for 17/31 and I wonder if 31 teeth could be cut into a blank sized for 30 equally well. The teeth will be a trifle narrower than the 29T version but that might be an advantage. I don't know if Simon would like to explore that as an alternative, it might be an interesting experiment.
                                                    Regards Brian
                                                    #438827
                                                    ega
                                                      @ega
                                                      Unsuspected layers of complexity!
                                                      Good point about coarse threads. Even for the later (no 1680) gearbox the manual has the stern warning":
                                                      "THE CUTTING OF UNUSUALLY COARSE PITCHES (IN EXCESS OF .125"  EXERTS EXCESSIVE PRESSURE ON THE LEADSCREW AND GEAR MECHANISMS. GREAT CARE SHOULD BE TAKEN SO AS TO MINIMISE THE LOADS IMPOSED."
                                                      Edited By ega on 26/11/2019 10:07:18
                                                      Edited By ega on 26/11/2019 10:07:40
                                                      Vain attempt to remove moronic smiley!
                                                      Edited By ega on 26/11/2019 10:08:32
