Allan B | 11/03/2017 13:16:36 |
![]() 133 forum posts 23 photos | ok this started to be talked about in another thread, so to stop me from taking it off topic too much I thought I would start a new thread, now me being dislexic and dyspraxic learning from books and written bits is not my strong point so you might need to bare with me while I try and get my head around this. from reading other threads I have worked out that it is possible to cut metric threads, with a quick change gear box on a Myford super 7, by just changing one gear, this gear being the 24 tooth input gear on the tumbler shaft. so my first question is, is this the gear that is being discussed? as by my understanding the input gear would be the one at the top, not the one with the arrow, but the only gear I can find with 24 teeth is that gear. so am i somewhere in the ball park, or have I got this whole thing twisted in my mind and I am going off on a random tangent? Allan |
RichardN | 11/03/2017 13:27:39 |
123 forum posts 11 photos | Yes that's the one- you don't get a 'perfect' thread pitch for every thread, but with a couple of other gears (to swap into that same place) you can do all the metric threads with more than sufficient accuracy for most needs... You do need to rotate the banjo to get the correct mesh, and if you use a small gear on that stud some lathes don't have quite enough adjustment... |
Brian Wood | 11/03/2017 14:11:38 |
2549 forum posts 39 photos | Allan, |
Allan B | 11/03/2017 14:29:48 |
![]() 133 forum posts 23 photos | thanks both for your replies. so just getting this into my head, to alter that 24 tooth gear, I need to adjust this bit there dosnt seem much movement to drop the gears down, but if it is only another 10 teeth it might just do it, so I need to get the 33 and 34 tooth gears which are about £10 each which is better than the £250 for the conversion kit, the next thing is without me going hunting through the net for something that I don't exactly know what I am looking at, where about's would I find a chart for the settings, using the 33 or 34 tooth gears, and what pitches the QC gearbox will cut. sorry if I am sounding thick on this, once I can get it all working and can play it will all become clear, but until then and it is all theory my brain dosnt like it too much. Allan |
Robbo | 11/03/2017 14:48:36 |
1504 forum posts 142 photos | Allan, John Stevenson used to sell a pair of 33 & 34 T gears from his online shop www.metoolsonline.co.uk, but had to close the shop, then sadly his wife passed away; don't know if he re-opened it. (Hope I remember it right John) Below is the gear chart he supplied with the 33/34T pair. (including typo on the BA chart). Hope he doesn't object to it being reproduced.
Edited By Robbo on 11/03/2017 14:50:49 |
Allan B | 11/03/2017 15:00:21 |
![]() 133 forum posts 23 photos | Thanks for that, I have just looked at his site, but it looks as if everything is at ?0.00 so looks as if it's closed, have sent him a PM and will see if he gets back to me. Allan |
Neil Wyatt | 11/03/2017 15:05:39 |
![]() Moderator 18990 forum posts 734 photos 80 articles | John's away for the weekend so he may not be able to get back to you for a day or two. Neil |
Allan B | 11/03/2017 15:15:00 |
![]() 133 forum posts 23 photos | Thanks Neil, I am in no major hurry as I don't need it right now, I am just experimenting with different things for when I do need them. Allan |
Glyn Davies | 11/03/2017 15:21:30 |
137 forum posts 51 photos | Robbo beat me to it, but I'll post this anyway - it's the table I use: |
John Stevenson | 11/03/2017 16:19:20 |
![]() Moderator 5068 forum posts 3 photos | OK, as Neil says I'm away for a long weekend but I'll get back to Allen and anyone else who pm's me on Monday night when I get back but from memory I'm carrying about 70 odd sets of steel gears. Made in the UK and even using the genuine Nottingham Myford cutters to do the job with. I'll shortly be adding more to the ranges as well. |
Allan B | 11/03/2017 17:56:04 |
![]() 133 forum posts 23 photos | Hi John, not a problem, enjoy your weekend away. Allan |
S.D.L. | 12/03/2017 18:23:16 |
236 forum posts 37 photos | Posted by Otley on 11/03/2017 15:21:30:
How do the top 3 rows read, The Metric and BA is clear, but haven't sussed the top three rows.
Steve |
Allan B | 12/03/2017 18:32:28 |
![]() 133 forum posts 23 photos | I could be wrong but in my second picture, the gear just above the arrow if the gear you flip over between fine feed and screw cutting, in the position it's in at the moment it is set for fine feed, so for turning to diameter with a auto feed, the top three rows corresponding with the settings on the gearbox showing what the TPI would be for say C8 is 500 something TPI so a very fine finish, then I think it was A3 is about 90TPI which wouldn't be as good a finish, but would cut a lot faster. This is as my understanding is, but as this is my thread of asking stupid questions I could be wrong 😂😂 Allan |
Brian Wood | 12/03/2017 18:34:36 |
2549 forum posts 39 photos | Hello Steve,
Edited By Brian Wood on 12/03/2017 18:35:01 |
Simon Williams 3 | 18/03/2017 13:06:50 |
652 forum posts 82 photos | There's always something to trip you up... I've spent a while over the last few days making a 33 and a 34 T gear, also a 24 and a 26. Gone to play with cutting metric threads with then this morning, and fallen foul of the fact that the gear A on my S7 is a 30/12 couple. Uh? Of course the answer in in the archive. I quote (from a thread dated 27.2.2012 called "Myford Quick Change Gearbox":- Mike, You are not getting the full story. So before you get in too deep...... 9. The guts of the boxes are identical and interchangeable apart from the shaft differences of course Think that's it. You have some way to go to get going. Dennis
And I do indeed have the older gearbox on a S7 of the same vintage. So, I have discovered that the banjo won't drop far enough to allow me to fit my new 33 and 34 gears, I'll have to modify the banjo slot to do so. Is this opening another can of worms? Having got the gears to mesh, I can in principle adjust the top lever and side lever selections to choose half the TPI the table above indicates, as my gearbox will be running at twice speed. I've yet to think this through, but I doubt I'm the first - does this work? Rgds as ever to all, and thanks for the help. Simon edited to remove a yellow winky face I didn't ask for....
Edited By Simon Williams 3 on 18/03/2017 13:08:11 |
Brian Wood | 18/03/2017 13:21:23 |
2549 forum posts 39 photos | Hello Simon, Send me a PM please with your email address and I can send you the drawing that way |
Simon Williams 3 | 18/03/2017 14:32:03 |
652 forum posts 82 photos | Brian - Have sent you a PM as suggested, and look forward to hearing further. Thx Simon |
john fletcher 1 | 18/03/2017 15:27:15 |
785 forum posts | I recently bought the two gears 33 & 34 from John and he said he more. I notice some one has post the chart as well.John |
Allan B | 18/03/2017 16:13:18 |
![]() 133 forum posts 23 photos | I have just ordered the gears off John, and my thread counter is now fitted, now to start playing. Allan |
John Stevenson | 18/03/2017 16:25:08 |
![]() Moderator 5068 forum posts 3 photos | At the risk of stealing Brian's thunder, may I pass a link on to his new book. Gearing of lathes for Screwcutting by Brian Wood, published by Crowood Press. I recently picked a copy up from ARC and it makes for very interesting reading and a lot of work has gone into this publication.
However from Crowoods page you can actually see part of this book and the modification that Brian talks about. |
