help – induma mill wiring
Home › Forums › Manual machine tools › help – induma mill wiring
  • #343900
    peter briggs 1
      @peterbriggs1
      hey guys can anyone help with this wiring? i cant get a sparks for love nor money and i need to get it working, any suggestions?imag1497.jpg
      #13160
      peter briggs 1
        @peterbriggs1
        induma milling machine wiring
        #343917
        Brian Sweeting 2
          @briansweeting2
          No wiring diagram stuck inside the box cover?
          #343932
          Martin Cargill
            @martincargill50290
            Single phase or phase? The pic shows two overload relays does the mill have a coolant pump or a power feed?
            #343954
            John Haine
              @johnhaine32865
              What a mess. Looks like there is a 3-phase cable sticking up top right of the lower relay except that the colours are black brown blue rather than black brown grey.
              #343956
              Andy Holdaway
                @andyholdaway
                It looks to me like power feed wiring – contactor, two overloads and a switch. If I were you I'd rip it out and start from scratch. It's not a complicated scheme. I'm sure if you search for a generic power feed schematic (Bridgeport?) you'll find something.
                #343962
                Emgee
                  @emgee
                  As Andy says You have 1×3 pole contactor supplying power via disconnected Grey, Green, Yellow wires to 2x3p overload units.
                  From this it seems there are 2 motors being fed from the overload units, perhaps the Br,Bk,Blu,g/y are the 3 phase power supply ? but using incorrect colour cores.
                  Or they may be a motor feed so need to be connected to the overload that matches the overload setting range from the motor FLC stated on the motor plate.
                  There are 3 black wires with white markers shown at the top right of the picture, do they go to a motor ? (suds pump ?) perhaps connect to the closest o/load unit.
                  Where do the 3 red wires shown at the bottom of picture go to and come from ? (spindle motor ?)
                  There is evidence of a flashover to earth from term 4 on the lower o/load so that unit may need replacing.
                  If you can identify where cables come from and number of motors and state if 3 phase more help may be forthcoming.
                  Emgee
                  #343964
                  Martin W
                    @martinw
                    This may be a stupid question but have you tried searching the internet for manuals, there is an example here but whether it is relevant to your mill I have no idea nor whether it contains wiring diagrams.
                    Martin W
                    PS
                    Can you give a rough indication as to where you live cause there might be somebody near enough that would be willing to come over and help you.
                    edit for PS
                    Edited By Martin W on 02/03/2018 11:05:13
                    #343970
                    KWIL
                      @kwil
                      I have the Erskine circuit diagram for Bpt power feed.
                      #343971
                      Les Jones 1
                        @lesjones1
                        Some backlground information might also be helpful. Was it supplied to you in this condition ? Has it been working and then stopped working and you removed all of the wires for some reason ?
                        Les.
                        #343973
                        Martin W
                          @martinw
                          Following on from Les's post do you have a model number and possibly an idea of when it was manufactured as a quick trawl through the net has shown up a large range of Induma machines, a snapshot can be seen here.
                          Martin W
