Cna anyone ID my old lathe?
Home › Forums › Manual machine tools › Cna anyone ID my old lathe?
  • #343782
    Kealan O’Carroll
      @kealanocarroll32466
      Hello chaps,
      I've just picked up an old lathe and would like to find some docmentation / info on it. Can anyone help me identify it please?
      I've put a post up to the same effect on practical machinist but haven't had any joy yet.
      I'm told it's German, and a search for "Germany" through the archives of Tony's site brought up a beling & lubke which looks quite similar but the handles on the apron are slightly different.
      [img]https://i.imgur.com/0cmKwYR.jpg[/img]
      [img]https://i.imgur.com/yT0r2ZX.jpg[/img]
      [img]https://i.imgur.com/GF0Xl66.jpg[/img]
      [img]https://i.imgur.com/UqwlcQ9.jpg[/img]
      [img]https://i.imgur.com/Pe1ZxLl.jpg[/img]
      [img]https://i.imgur.com/kBmXe9D.jpg[/img]
      [img]https://i.imgur.com/1DmQ1Ji.jpg[/img]
      [img]https://i.imgur.com/SYHh49D.jpg[/img]
      [img]https://i.imgur.com/R5AGs3h.jpg[/img]
      [img]https://i.imgur.com/KmgSYzv.jpg?1[/img]
      [img]https://i.imgur.com/YpWNK3g.jpg[/img]
      Edited By JasonB on 01/03/2018 13:11:23
      #13159
      Kealan O’Carroll
        #343793
        David Standing 1
          @davidstanding1
          Welcome
          Your images don't work as posted.
          You either need to edit them and take out the [img] and [/img] tags and then insert a http link per the icons above your post, or post them into a photo album here and link them from that smiley
          #343796
          Kealan O’Carroll
            #343798
            David Standing 1
              @davidstanding1
              Working now yes
              #343799
              larry Phelan
                @larryphelan54019
                Looks like a fairly hefty bit of kit !
                Would love to hear how it shapes up.
                #343804
                Phil Whitley
                  @philwhitley94135
                  When you get it set up on its legs, send a pic to [email protected] or have a troll through the worlds biggest machine tool archive at http://www.lathes.co.uk. Very well made machine by the looks of it, and gap bed too! Good luck!
                  #343831
                    Looks to be a useful machine, especially if you can find the changewheels to connect mandrel to the gearbox / leadscrew. Keep us abreast of your progress, please!
                    #344082
                    Kealan O’Carroll
                      Hi all,
                      I got it put together today (eventually). I broke a timber lifting frame and ended up putting up part of a scaffold tower inside the garage and incrementally ratchet strapping it up to it's normal height and then bolting the legs on to the bottom of it. An engine crane would have been ideal!
                      I've got around 8 changewheels for it, but haven't checked the numbers yet (I did see a 127) so I'm not sure what pitches I can cut yet.
                      The carriage does get tight when the tailstock is off and it's moved right down to the end of the ways, so they're probably worn but if I'm spending most of my time within 6 inches of the chuck then I'm thinking it may not be an issue?
                      I ran it and made some chips from a scrap bolt I had laying about…at least it runs! I have a load of HSS blanks I got with it, but some of the smaller ones are lost in the toolpost and the larger bits that do actually fit the toolpost are ground miles above centreline. It's dead quiet with just the spindle running, but the tumbler is horrendously noisy when engaged in either direction, as is the powerfeed speed selector gearbox. The 3 – jaw also took both hands on the key to budge, so I took the jaws out and the spiral & the jaws are all gummed up in what looks like old dried up grease so that will need stripping and cleaning.
                      The half nut and, handwheel, and slides all have a lot of backlash too; I don't know if this will actually be an issue or if I can just go beyond my start point and take up the backlash to work around it?
                      Link to the assembled picture below; I don't know how to embed it. I'll post some pictures of the lifting arrangement later if anyone wants a laugh…
                      http://www.model-engineer.co.uk/albums/member_photo.asp?a=47788&p=792983
                      #344086
                        Kealan,
                        I will be very interested if you find the maker … because it looks rather like a 'big brother' to my own mystery lathe:
                        The inboard tumbler reverse arrangement should help with identification … but I've got nowhere yet.
                        Yes, I do have the rest of it.
                        #344091
                          idea
                          IXL/Ehrlich looks promising: **LINK**
                          http://www.lathes.co.uk/ixl/
