The 127 will go on the bottom , 60 idler on the middle and 70 on the top stud , the tail end sleeve should unscrew so you that you can then fit a bigger gearwheel on the top stud , well at least mine does , ive only needed to do it once to get an 85t wheel on.
regards Geoff
