Does anyone have a table of the lathe and milling machine limits?
You will struggle to find them "free" – they are usually National Standards (BS, EN, ISO, DIN etc.) and all are sold, not made freely available.
And the relevant authorities know how to charge !
BS ISO 1984-2:2001
Test conditions for manually controlled milling machines with table of fixed height. Testing of the accuracy. Machines with vertical spindle costs £140 from the BSI
I know I have a couple of lathe alignment charts (Harrison & Gildemeister) at work for manual machines, but not sure if I have one for the XYZ turret mill ( the only manual mill in the works) – I'll have a look on Monday.
Quite a few of the older machine tool fitters I worked with used to quote a "rule of thumb" for alignments of "1 thou per foot" – this may have been applicable to the larger manual machines built in the '60s & '70s (the fitters came variously from the likes of Asquith, Butler, Churchill Redman, Crawford Swift etc.- pretty well all of the machine tool builders that used to proliferate in the Halifax area), but that was somewhat more relaxed than the standards required for the CNC machines that my former employer used to rebuild/retrofit, where less than 1/2 a thou per foot was more usual.
Nigel B.
