Facing bar ends parallel on the lathe.
Home › Forums › Beginners questions › Facing bar ends parallel on the lathe.
  • #489560
    Robin Graham
      @robingraham42208
      This arises because I got involved with a project to make a riser for a VMC mill as detailed in another thread . It got me thinking. How does one turn the faces of a bar parallel?
      The inimitable doubleboost just turned the piece end-for-end in the 3-jaw. I tried that with with a 4" diameter billet, making sure the workpiece was referenced to the flats on the jaws rather than the grippy bits. It turned out about 0.03mm out of parallel across 100mm. Not good!
      I'm wondering if it can be done better by bolting to a faceplate which could be skimmed before attaching the work?
      Robin
      #10363
      Robin Graham
        @robingraham42208
        #489561
          No need to skim your faceplate unless there is something measurably wrong with it. You could ruin a good plate.
          But yes it's more reliable to bolt to faceplate to get faces parallel. Holding in the 3 jaw by a relatively small area can allow movement under load. Or bits of swarf or even duff chuck jaws can throw it out too. And always tap the the job home carefully with a brass hammer to make sure job is seated on all jaws. A 4 jaw would give better grip than a 3.
          #489562
            PS. But the faceplate method can mean you end up with the two ends parallel to each other but out of square with the outer diameter. This happens if the first unmachined face bolted to the faceplate is not square to the OD to start with — as is common with power hacksaw cuts on stock. Probably for a riser, the OD is non-functional so won't matter if it is not square to the faces.
            If you want to get the OD square to both ends and both ends parallel, the best way would be careful set up in the four jaw. Get OD running true at both ends and job seated firmly on all four jaw steps with a brass hammer. Then carefully machine one end. Then either flip it around and do the same again or use the faceplate to do the second face.
            #489563
              Using a tailstock centre would help keep things in place in the chuck too, facing across to leave a small tit in the middle to be removed last and perhaps even relieved a little so load bearing is around the outside.
              Edited By Hopper on 08/08/2020 05:12:34
              #489564
              Neil Lickfold
                @neillickfold44316
                1st to check, is the cross slide actually square to the run of the lathe. Some are not and are not adjustable in any way to make them square. Which is why on some older machines, you need to set the compound to get a flat face.
                #489566
                Ady1
                  @ady1
                  It's not really a lathe job, there are too many potential errors
                  I would use a shaper (or if I had one a grinder)
                  the faces must be parallel, and flat, and at right angles to the diameter
                  Lathes do round bits and shapers do flat bits
                  I believe that most lathes are set up a bit convex or concave to start with, so even the facing off isn't really flat which doesn't matter with most jobs but when you need it really spot on you need the right machine
                  I suppose a decent mill with a fly cutter would also do flat
                  Edited By Ady1 on 08/08/2020 07:14:53
                  #489567
                    As you were using the outside jaws and the work was not back against the chuck it would be easy enough to get a dti onto the previously faced now back face of the work to check it for true running. Only tap the work back against the jaws if you know they are totally true.
                    Regarding hoppers point about ends not parallel that is easily solved by taking a cut off the OD at the same setting when facing the first end.
                    Edited By JasonB on 08/08/2020 07:16:58
                    #489573
                      Posted by Ady1 on 08/08/2020 06:49:19:
                      Given the purpose of the exercise … That would seem the obvious choice, yes
                      DC31k
                        @dc31k
                        Have a look on the Stub Mandrel site for Schlessinger's work and then you will know rather than merely believe.
                        #489579
                        Essm
                          @essm
                          Good grief man thats a tad over one thou – I think its fantastic!
                          #489583
                          John Haine
                            @johnhaine32865
                            Obviously the person who has the requirement here has a mill, though it might be in pieces. But this is an obvious milling job, it would need a large lathe and chuck to hold it accurately for turning. I had a similar issue facing and drilling a pendulum bob and did that on the mill.
                            Surely it must be easier for the mill to be reassembled and used rather than a dodgy lathe setup?
                            #489584
                            Phil H1
                              @philh196021
                              Essm,
                              You beat me to it. I would say that 0.03mm in a 3 jaw chuck is quite good. You could also try checking the jaws with a DTI to see if that is the cause of this small error.
                              For reference, the jaws on my had it from brand new, top of the range, very expensive 4 jaw chuck is out by about 0.001".
                              Phil H
                              #489588
                                Just measured the 100mm dia EN3 flywheel blank I turned the other day in 4 places around the rim no more than 2/10ths deviation which is 0.005mm so I must be doing something right though did not clock the back so maybe I could have done better but job did not need it.
                                #489592
                                mgnbuk
                                  @mgnbuk
                                  But not too bad for a 3 jaw either ? Close enough to sort with a scraper if you are in a position to measure the error.
                                  Could you not put the component between centres, face one end, reverse the part & face the other ? Should be pretty close to parallel done that way. May need a hole drilling & tapping in a non-working area to take a drive peg. I have a cylinder square at work that appears to have been machined that way, complete with an off-centre tapped hole at each end.
                                  Nigel B.
                                  #489606
                                  Vic
                                    @vic
                                    The riser block can be fitted in one of three positions. Given that Chinese machines often have “errors” built into them it might actually be and advantage to have a slightly less than square riser?! laugh
                                    #489608
                                    blowlamp
                                      @blowlamp
                                      Turn it between centres and both faces will be parallel with each other.
                                      Face the tailstock end first, remove part from lathe, refit back between centres with faced end now located at headstock. Face the tailstock end. Job done.
                                      Martin.
                                      #489609
                                      Graham Meek
                                        @grahammeek88282
                                        Martin you came in while I was writing,
                                        I would simply rough out somewhere near size and centre each end with a protected, or recessed centre. Drill and tap at one of the mounting holes on each face for a driver peg. Then mount the work between centres to take a light skim down each face and over the O/D if desired.
                                        This does assume that the lathe is already set-up correctly.
                                        Gray,
                                        Edited By Graham Meek on 08/08/2020 11:26:09
                                        #489615
                                        blowlamp
                                          @blowlamp
                                          Posted by Graham Meek on 08/08/2020 11:25:33:
                                          Gray,
                                          Agreed, Graham.
                                          If a fairly large central relief can be made at each end, which leaves a face of sufficient size for its intended purpose, then a much smaller area will need facing and the concave/convex facing issue becomes almost irrelevant.
                                          Martin.
                                          #489629
                                            Posted by Essm on 08/08/2020 09:32:38:
                                            Oops. I missed that. Yes you are not going to get much better than that on the average lathe.
                                            #489636
                                              Posted by DC31k on 08/08/2020 09:13:50:
                                              I am genuinely surprised to see ‘the book’ available there
                                              … ‘though of course that is not all of Schlesinger’s work.
                                              Edit: But time has passed since this discussion:
                                              https://www.model-engineer.co.uk/forums/postings.asp?th=132159
                                              Edited By Michael Gilligan on 08/08/2020 14:03:01
                                              #489901
                                              Robin Graham
                                                @robingraham42208
                                                Thanks for replies. I understand that milling is the 'natural' technique for making the ends of a bar parallel, but for various reasons it's not an option here.
                                                Several good ideas for doing it on the lathe though – I'll experiment. I think Martin's / Gray's suggestions of turning between centres will be the first experiment – it's a technique I've never used, so it'll be fun and seems to be guaranteed to work – provided the lathe's set up correctly of course!
                                                Good to hear that 0.03mm isn't too bad given that it's a Chinese lathe/chuck. The chap I'm working with has suggested referencing off the chuck face using parallels, which is another avenue to explore. I guess that's going to be more accurate than referencing from the flats on the jaws.
                                                Hopper – I dug out the face plate, there was a weird contrivance bolted to it, what's that I thought, then it came to me – it's the gizmo! That's from a while back!
                                                Robin.
                                                #489902
                                                Paul Lousick
                                                  @paullousick59116
                                                  " a weird contrivance bolted to it"
                                                  Hard to tell without a photo but could be a Keats angle plate for holding round parts on a faceplate.
                                                  Paul
                                                  #489907
                                                    Posted by Robin Graham on 10/08/2020 00:02:56:
                                                    Why take a guess, put a Dti on the chuck face and see what it runs like, no point in using that if it's too far off, same as knocking it back against the chuck jaws if they are off.
                                                    Also once you pull the parallels out or before turning if leaving them safely secured ion place put a dit on the back face of the work to check runout, a bit like this but you will need the rear one on the cross slide so you can move it out the way of the jaws
                                                    Edited By JasonB on 10/08/2020 07:07:37
                                                    #489909
                                                    pgk pgk
                                                      @pgkpgk17461
                                                      A lazy but wasteful way may be to just chuck up a length, face the free end and then a deep groove near the chuck end just deep enough for whatever fixings are needed and cleaned up… then off the lathe finish cutting through with a saw, back on the lathe and bore out a central depression below your clean face.
                                                      pgk
