Yet another unidentified tool
Home Forums General Questions Yet another unidentified tool
  • #600716
    PaulG
      @paulg46657
      Not as esoteric as some other submissions but it has me beaten. So can anyone enlighten me? The blade is spring loaded and retractable but I don't know whether it planes, scrapes or cuts. Obviously made for a very specific purpose for which I have yet to develop a need.
      #28728
      PaulG
        @paulg46657
        #600722
        ega
          @ega
          It looks to be shop-made so perhaps some rather special purpose.
          #600724
          Bill Davies 2
            @billdavies2
            No idea,Paul.
            It looks as though the ring is used to hold the base against something, presumably the work? The base clearly butts against the edge of something. Do you push the screw to force the blade out? Does the screw control the depth of cut?
            Bill
            Edited By Bill Davies 2 on 05/06/2022 16:54:56
            #600725
            Martin Connelly
              @martinconnelly55370
              It would be good for removing excess glue from the edging strip on tables and worktops.
              Martin C
              #600728
              Bizibilder
                @bizibilder
                A veneer or banding trimmer?
                #600730
                PaulG
                  @paulg46657
                  Bill,
                  I have checked with the actual owner of the tool and it seems that:
                  Undoing the knob allows the blade to move out, pulled by an internal tension spring. The blade can then be pushed back in against the spring tension until the protruding spigot reaches the end of the slot at which point the blade is retracted. So no use as a plane as the blade retracts as soon as it digs in. So maybe for protecting the surface.
