X1 Mill lifting mechanism
Home › Forums › Workshop Tools and Tooling › X1 Mill lifting mechanism
Viewing 15 posts - 1 through 15 (of 15 total)
  • #203842
    Frances IoM
      @francesiom58905
      the latest MEW #233 has an article describing milling of a 50mm thick block of Al to raise the column – the photographs also appear to show some motorised mechanism to raise + lower the head (any change to tooling usually needs a tedious multirotation of the awkwardly placed handle) – has anyone published any mechanism to do this especially if manual adjustment also is required.
      Has anyone used gas struts to oppose some of the mass of the head making raising less of a chore ?
      #17820
      Frances IoM
        @francesiom58905
        #203847
        Peter Hall
          @peterhall61789
          I have 2 X1 mills. I have not done any of the mods you ask about, but I did install a thrust bearing on the rise and fall screw. Still needs tedious multirotation, but essentially removes all effort in turning the wheel, so makes it fast and easy. Did the same to the x and y axes too, with similarly happy results. I can't remember exactly how I did it now, but if you're interested I will try dredging through what passes for my memory these days and give you a how-to.
          Pete
          #203849
          TrevorK
            @trevork
            I have fitted a gas strut. In MEW 150 David White describes how to do this. I also fitted a replacement bearing block and bearing to the Z axis from a design by Graham Meek. There are a couple of photos in one of my albums. These two mods have made a dramatic improvement to moving the head but I'd also be interested in motorising the Z axis.
            #203852
            Peter Hall
              @peterhall61789
              Yes. I did the X and Y axis bearings to Graham Meek's design.
              Pete
              #203853
                Rich (Firebird) posted about his Z axis feed  over on MEM forum
                Edited By JasonB on 10/09/2015 20:59:37
                #203860
                Frances IoM
                  @francesiom58905
                  is there a ref to Graham Meek’s work please
                  #203872
                  Thor 🇳🇴
                    @thor
                    Frances, I have sent you a PM.
                    Thor
                    #203879
                    Robbo
                      @robbo
                      Nice work by Rich.
                      He seems to get through a lot of overalls!
                      #203897
                      TrevorK
                        @trevork
                        #203900
                          The Myford powered lead screw is written up in ME, which may help anyone wanting to motorise the X1 z-axis.
                          P.S. the washing is a major feature of all his project s
                          #203902
                          Bernard Reilly
                            @bernardreilly64467
                            Hi all has anyone carried out a similar mod on a Warco WM14 mill which has a very heavy mill head and difficult to access lead screw & hand wheel . No problems on downward direction but a pain in upwards direction as it has a 5 TPI lead screw. Enquires up until now have ruled out a single phase geared motor. I do not have electronic knowledge to take stepper or server motor route.
                            Thank you all B Reilly Glasgow
                            #203907
                            mechman48
                              @mechman48
                              'Hi all has anyone carried out a similar mod on a Warco WM14 mill which has a very heavy mill head and difficult to access lead screw & hand wheel'
                              Would be interested to see method & maybe adapt to fit WM16…
                              George.
                              Edited By mechman48 on 11/09/2015 12:50:02
                              Edited By mechman48 on 11/09/2015 12:50:31
                              #203908
                              Bob Rodgerson
                                @bobrodgerson97362
                                ThoseOveralls remind me of certain scenes in "Breaking Bad"
                                #203909
                                mechman48
                                  @mechman48
                                  Hmmm… seem to have got my 'quote' editing screwed up… but you get my drift.
