Which Lathe???
Which Lathe???
Home Forums General Questions Which Lathe???
Viewing 25 posts - 1 through 25 (of 78 total)
  • #27257
    Paul Smith 37
      @paulsmith37
      I need a bit of help here.
      #462460
      Paul Smith 37
        @paulsmith37
        Well this has probably been done to death, but ill ask the latest opinion.
        Ive bought a Myford ML10 Metric a while ago, its a great little machine, but after a while i find myself hankering for a bigger unit. Its got a raft of extras with it, but i find myself being limited by what the unit can do. I hastily bought it without doing my research first. Im limited by the MT2 in the headstock.
        The foot print of the lathe is great, small, compact and light. It makes a great finish and is very capable, to a point.
        So my next route up is an ML7 with a big bore kit. Roy Milner has stopped making them, i messaged him a few days ago.Myford themselves make a big bore lathe based on the ML7 , wether they will sell me just a big bore headstock i i dont know.?They are closed at the moment. Do you know anybody else who makes one?
        Roy was doing the headstock for £1500. Now you can buy a new lathe for that, but it will be chinese but 26mm capable.
        I hear Warco and Chester gets good reviews, but also some terrible ones too. I prefer to stay English i think.
        So i think ill change my route to an Myford ML7 and find the metric conversion for it, and try and find a big bore headstock .So the question is, which ML7?
        One of the gearbox versions seems to be the way to go, whilst im changing over.
        The other limiting factor is the space i dont have, the ML7 will fit, but a Boxford or similar toolroom lathe wont.
        Im doing general fabrication of tools and log splitters,belt sanders etc for a hobby, i cant for one fit a 17mm shaft thru the headstock as its mt2.
        Ive a 52 inch width available , slighty more if the unit can be pushed in at an angle then squared up afterwards due to a shelving support, which i could move if i have to.
        Thanks in advance for taking the time to reply.
        Your views are greatly received.
        Edited By Paul Smith 37 on 05/04/2020 12:11:46
        #462490
        Journeyman
          @journeyman
          See *** Journeyman's Workshop *** for my views on choosing machinery!
          Paul Smith 37
            @paulsmith37
            Thats a good and comprehensive read that. well put together !
            #462518
              Posted by Paul Smith 37 on 05/04/2020 12:10:02:
              Ive bought a Myford ML10 Metric a while ago … find myself hankering for a bigger unit.
              The other limiting factor is the space i dont have, the ML7 will fit, but …
              Tricky one, but despite objections to Chinese, one of them may be the answer. Going 'English' reduces the available choice particularly if a good condition big bore must fit into a small space. It may take a while to find a suitable classic machine, especially if metric is also important. (Buying second-hand, condition is more important than make and model.)
              Myford suffer from the name attracting premium prices. If money is no object Triona list a Connoisseur at the moment. It's said to be in unused condition. Price on Application; no harm in asking, but make sure your pacemaker has a fresh battery!
              Health emergency apart an important advantage of new Chinese machines is they're available off-the-shelf in a wide range of different sizes. The machine that fits best into the available space can be picked out of a catalogue.
              Edited By SillyOldDuffer on 05/04/2020 16:37:18
              #462529
              thaiguzzi
                @thaiguzzi
                Posted by Journeyman on 05/04/2020 14:07:54:
                Well put together website. Well done.
                #462534
                Enough!
                  @enough
                  Paul, you,of course, know your own needs but if "big-bore" is driving your choice make sure that you actually need it.
                  I started with an early Chinese lathe and then got an ML7. I kept the Chinese lathe as well because of the larger bore. I actually used that machine, I think, once in 7 years and then mostly "because it was there".
                  I finally sold that lathe and haven't missed it.
                  ymmv.
                  #462593
                  Paul Smith 37
                    @paulsmith37
                    That connoisseur will be big bucks , fat end of 8k id say. But tanks for the heads up.!Im not a collector, i want to use it. Quite why you'd want to collect lathes is beyond me , watches are easier to store.
                    #462594
                    Paul Smith 37
                      @paulsmith37
                      Ive also wondered about boring out the spindle and keeping a spare to swap back should i need to.
                      Edited By Paul Smith 37 on 05/04/2020 19:39:12
                      #462595
                      Paul Smith 37
                        @paulsmith37
                        So what chinese lathes are any good?
                        #462606
                        Dave Halford
                          @davehalford22513
                          Harrison M300, there's 4 on ebay in the UK, 2 might be OK, 2 are junk.
                          Prices are pretty much the same
                          #462610
                          Andrew Evans
                            @andrewevans67134
                            My advice is go for something as big as you can fit in your space.
                            #462615
                            Clive Brown 1
                              @clivebrown1
                              Posted by SillyOldDuffer on 05/04/2020 16:35:49:
                              IIRC I noticed that same Myford a few days ago at £14K. Perhaps it was April 1st.
                              #462616
                              Paul Smith 37
                                @paulsmith37
                                £14k crikey o riley. ill leave that there.
                                Thanks Andrew
                                Thanks Dave. ill check them out
                                Thanks Mr Banders
                                Thanks Mr Duffer
                                #462622
                                Hollowpoint
                                  @hollowpoint
                                  What about a Boxford with the rear mounted motor. About the same size as the myford but a better machine.
                                  #462623
                                  Paul Smith 37
                                    @paulsmith37
                                    Posted by Hollowpoint on 05/04/2020 21:14:18:
                                    Have you a model type? whats the spindle capacity?
                                    #462624
                                    Hollowpoint
                                      @hollowpoint
                                      Im not up on my Boxford models, but ME10 and CSB come to mind though ive seen models A, B, abd C with rear mounted motors too.
                                      The underdrive models are CUD, BUD and AUD.
                                      I believe the spindle bore is about 3/4"
                                      #462625
                                      Clive Brown 1
                                        @clivebrown1
                                        The standard Boxford passes 3/4", (3MT). Bigger bore versions were made but rare.
                                        All are screwcutting except any designated "T" which are very basic.
                                        Model A:- Screwcutting g/box., power cross feed & long. feed
                                        Model B:- Power cross-feed & long. feed
                                        Model C;-Power long. feed.
                                        #462633
                                        Hollowpoint
                                          @hollowpoint
                                          Thinking about it the under drive models probably take up less room than the rear drive models and not much more than a ML7. About comparable to a super 7.
                                          I understand you said you don't have much room but the only difference is the cabinet rather than being bench mounted.
                                          #462635
                                          Paul Smith 37
                                            @paulsmith37
                                            Im looking into the Boxford box lathes, they maybe very efficient in what they do, which is of course the primary goal, but lack the charisma of a myford super 7 style lathe. Or Is it me just being a tart?
                                            #462640
                                            Martin Hamilton 1
                                              @martinhamilton1
                                              I have always thought Myfords have been way over priced, as an example Home & Workshop Machinery has a Myford Connoisseur big bore for a whopping £14000 + vat £16800 total.
                                              #462642
                                              Paul Smith 37
                                                @paulsmith37
                                                Posted by Martin Hamilton 1 on 05/04/2020 23:17:23:
                                                Thats a lot of money for a lathe.
                                                #462645
                                                Hollowpoint
                                                  @hollowpoint
                                                  Posted by Paul Smith 37 on 05/04/2020 22:31:35:
                                                  Function over form for me. But I get where you're coming from. If you want charm and charisma buy a cowells me90. 😊
                                                  I don't think an ML7 is a massive upgrade over your ML10 to be honest. I had an ML10 and I actually preferred it!
                                                  I started with a very basic Raglan Loughborough training lathe which I quickly upgraded to an ML7 when one came along at a price I could not reuse with loads of accessories. I only owned the ML7 for about 12 months. I kinda regretted selling the Raglan and the ML7 actually seemed like a bit of a down grade. I gained screwcutting with the Myford but the Raglan was more rigid, had a bigger bore, bigger centre hight, was smoother and was metric. After the Myford I bought a Boxford AUD which had the best quality's of bothe the Raglan and the Myford. I can honestly say I have never looked back and I can't ever imagine parting with my Boxford now.
                                                  #462651
                                                  Bazyle
                                                    @bazyle
                                                    As a Boxford owner I only see Myfords at exhibitions and they always strike me a 'dinky' and 'cute' as they are invariably polished up a part of a demonstration. Bit like having a fancy sports car seems nice but you still need a Landrover to pull the log trailer.
                                                    #462656
                                                    Steviegtr
                                                      @steviegtr
                                                      I took out my headstock shaft, if that's what it is called. So I could take it to the autojumble with me to match a chuck for it. One thing I did think was if you considered opening up the bore. I.E Making a new shaft. Then all the gears would need remake , or rebore etc. Big job I guess. I have had the Super 7 a while now & it is a great machine , but I can appreciate the limits of a MT2. Not a problem for me as I have a cut off machine & bandsaw. But loading large stock a no-no.
                                                      Steve.
