What’s your best tool purchase ?
Home › Forums › General Questions › What’s your best tool purchase ?
Viewing 25 posts - 1 through 25 (of 52 total)
  • #23874
    Gas_mantle.
      @gas_mantle
      #189502
      Gas_mantle.
        @gas_mantle
        I'm just starting out in this hobby and slowly building up a set of tools, just wondered what's your best purchase ?
        What's your worst ?
        #189510
        Anonymous
          Best is the next thing you buy, worst!!!, there's no such thing☺
          #189514
          Douglas Johnston
            @douglasjohnston98463
            Try not to buy cheap when it comes to important items like measuring instruments. It often makes economic sense to buy quality tools as they will last a lifetime and the enjoyment in using them will make you feel good. A poor tool will cause endless heartache and will probably be replaced at some point in the future.
            Doug
            #189516
            Clive Hartland
              @clivehartland94829
              Without doubt a good quality Lathe and Milling machine. Buy quality if you can and then learn how it works and how to use it.
              Accessories as you need them. Drills and taps and good files.
              #189523
              martin perman 1
                @martinperman1
                Peter,
                My best purchase is the small machine I bought very recently, I dont actually do model engineering but I do restore old stationary engines for which I make my own fuel tanks, its a roller/guillotine/box bender which means I can get rid of my modified mangle and angle iron.
                Martin P
                #189524
                Alex Collins
                  @alexcollins55045
                  Like most people, I buy tools as and when I need them.
                  If it's a real 1 off and I can borrow a tool then so be it. If I need it a 2nd time I will usually buy it.
                  As for the Best tool, Anything that I have paid Good money for good quality. They work and last well.
                  Dormer Drills, Taps and Dies come high up on the list.
                  If you are working in Brass / Bronze get a Slow Spiral Drill set. Drilling is an absolute breeze. No Snatching or Grabbing.
                  Map Gas torch for Silver Soldering. (see the 16mm IDRIS Thread) has made Silver Soldering so easy
                  My Myford Lathe so nice to use compared to the Chinese machine I bought and started with.
                  The worst Tool ?
                  Probably the cheap milling vice. I gave it away after I used it once.
                  The trick with tools is to buy the best you can afford. The cheapest often fails to last or perform well.
                  #189528
                    Worst? Cheap drills, nothing worse than snapping a big drill in something.
                    Best? My mini-lathe. Without it I would/could never have gotten into this hobby.
                    Cabinet Enforcer
                      @cabinetenforcer
                      Best, without a shadow of a doubt, 6×4 band saw. Even though it was 2nd hand junk that needed fettling.
                      Second best, 6″ mitutoyo digital calipers, 10x the price of an aldi set and worth every penny. Though a couple of aldi calipers for mucky work are great too.
                      #189557
                      Thor 🇳🇴
                        @thor
                        My best buy would be the Emco Compact 8 I bought decades ago, it is still delivering good work. Worst buy, as Neill says, cheap drills.
                        Thor
                        #189559
                        john carruthers
                          @johncarruthers46255
                          best tool was a 2nd cut Sheffield steel file, a joy to use.
                          worst were some 'cheap' drill bits.
                          #189564
                          Oompa Lumpa
                            @oompalumpa34302
                            Best tool I own, my glasses. Second best is cash. Can accomplish most everything with these two tools.
                            graham.
                            #189566
                            Jesse Hancock 1
                              @jessehancock1
                              Worst tools : Indian spanners. Absolute rubbish and dangerous with it, I might as well have made paper gliders out of the money.
                              Best but not including ridiculously priced snapon are German SACO spanners they have never lost against loctite, self locking nuts, garage air-guns, or rusted/corroded nuts and are still in excellent condition.
                              I also have a set of mini screw drivers made by CW of Germany they are good but they weren't cheap either.
                              I think over the years I have grown a preference for German hand tools. Items which have everyday use anyway but not necessarily model engineering.
                              #189568
                              mick70
                                @mick70
                                worst cheap drills.
                                best is hopefully going to be my 1939 southbend 9" lathe when it arrives and i have got it sorted.
                                brought some of bits back other week just waiting for trailer to pick it up.
                                #189573
                                Involute Curve
                                  @involutecurve
                                  Best is a Hurco Miller for 60 quid, and this was tha cost of moving it, and a Facom socket set, expensive but worth it, worst is cheap hacksaw blades……..
                                  #189575
                                  martyn nutland
                                    @martynnutland79495
                                    Not my best buy, Peter, but if you want a bit of exotica in your early days you might try a tailstock scroll chuck from Chronos. It's hard to find on their website by describing it, so use the reference number 154032.
                                    I'd been looking for one of these for a tong time, in preference to the rotating Jacob's variety. A firm in America called Bison make them and I'm sure they're a splendid engineering job, but they cost mega-bucks. The Chronos job is cheap and cheerful (about 70 quid) and, I think, as the Americans would say, it's quite 'neat'!
                                    Enjoy your machining and good luck.
                                    Martyn
                                    #189577
                                    Nick_G
                                      @nick_g
                                      Posted by martyn nutland on 12/05/2015 09:29:03:
                                      Martyn
                                      I thought Bison was a Polish company. – Or is there more than one.?
                                      Nick
                                      #189578
                                      Nobby
                                        @nobby
                                        A Myford Super 7 rusting away in a coal bunker for a fiver needed some work
                                        Nobbyusing fixed steady
                                        #189579
                                        GarryC
                                          @garryc
                                          Hi Peter
                                          Best would be the Warco Lathe that I have now also on a par with it the Chester Mill. Worst has to be a drill bit sharpening jiggy thing that I haven't even been able to try and also a tiny 3" rotary table that I could never get anything to fit onto – I have a 6" now which is great. Cheap drills I'm not so sure about now as a lot depends as to how and when they are used and what they are asked to do, they can be handy to buy and have in bulk especially if the budget is tight and you get asked or need to do some less critical jobs – but you absolutely can't be without quality drills to hand to be able to make the choice me thinks.
                                          Have fun with the new lathe.
                                          Garry
                                          #189584
                                          Ady1
                                            @ady1
                                            In the past I found that Halfords did some really good gear (tools for life purchases) at very reasonable prices
                                            Don't know what they are like nowadays
                                            #189585
                                            Ady1
                                              @ady1
                                              It's a "unimat style" 3 jaw chuck, the old unimat SL used them and they can be beautifully made
                                              Their downside is they don't grip as tightly as a jacobs keyed chuck and you bash your fingers a lot getting them unscrewed
                                              There is a keyed version, item number 281343093107 on a well known auction site, 120 quid though
                                              Edited By Ady1 on 12/05/2015 10:57:20
                                              #189586
                                              Philip Rowe
                                                @philiprowe13116
                                                Not exactly a tool purchase – a VFD drive for my Super 7. I promised myself one when I retired and over the weekend fitted it. Not the easiest of tasks on your own, the fitting and wiring was a breeze but physically moving the lathe out for access and returning to its old position did tax me a bit. Pinch bars and rollers are all very well but the bottom of the Myford cabinet is not exactly smooth for rollers.
                                                Anyhow now completed and to say I'm pleased is a bit of an understatement, so smooth and quiet in operation and almost instant speed changing.
                                                My only regret is that I didn't buy one years ago.
                                                Phil
                                                #189589
                                                Anonymous
                                                  Excluding the machine tools themselves my best buy by far was a decent (Newall) DRO for the vertical mill. My worst buys were assorted cheap cutting tools. I now only buy brand name cutting tools.
                                                  #189592
                                                  Bob Brown 1
                                                    @bobbrown1
                                                    I would say I have a similar view to Andrew, my DRO on my Marlow mill has proved invaluable when drilling holes from holes on a PCD to holes around the likes of a valve chest. The Marlow is probably not the best tool for this job but it works all be it with a bit of effort raising the table. Worst choice is cheap cutting tools particularly drills as they are in the main not worth the trouble.
                                                    That said some times a view can be taken that the things like cheap DIY power tools do offer an option when they come with a three year warranty such that they are disposable.
                                                    Bob
                                                    #189595
                                                    Nick_G
                                                      @nick_g
                                                      I will echo those that listed a DRO as the most beneficial. It makes life so much simpler in many ways. e.g. Just the simple matter of my machines being calibrated in metric and most of the time I work in imperial being just one. – Although a pro machining mate of mine still insists I should have got myself proficient with the machines first before I bought them.
                                                      On a more affordable front, I would say the Diamond tool holders from Eccentric engineering would be 'up there' with my best purchases.
                                                      Bad tools. ………….. Well exactly that.! Everything that I have bought that was cheap has either been replaced or is on the list to do so. So they have not been cheap after all.
                                                      Nick
