What to do,what to do.
Home › Forums › Beginners questions › What to do,what to do.
Viewing 25 posts - 1 through 25 (of 36 total)
  • #9735
    Roger Hulett
      @rogerhulett83124
      #416365
      Roger Hulett
        @rogerhulett83124
        I have now saved up enough RDG vouchers to buy a self centering 4 jaw chuck.
        I have a South Bend lathe with both 3jaw and 4 jaw chucks. A small Pools horizontal mill.vertical slide and boring table.
        Am I doing the right thing, or is it going to be a waste of vouchers
        #416369
        Anonymous
          Not for me to say, but I've never used, owned, or missed, a 4-jaw self-centring chuck.
          #416376
          John Haine
            @johnhaine32865
            I agree, I can't see the point. The whole beauty of 4 jaw chucks is that you can accurately centre things, where you want the centre. If your 4-jaw SC chuck is not dead accurate it won't even centre square material! Personally I'd prioritise a collet chuck.
            #416378
              I guess they're good if you have a lot of square stock to machine?
              Wouldn't get much use in my workshop. Although adjusting an independent 4-jaw to centre is a bit of a faff, it's not worth me having a special chuck just for square stuff.
              Nicholas Farr
                @nicholasfarr14254
                Hi Roger, I have to agree with Andrew and John, to the letter.
                Regards Nick.
                P.S. you may think it has more gip on round material, but it would have to be truly round, otherwise you may well get one jaw not taking much load.
                Edited By Nicholas Farr on 27/06/2019 11:41:48
                #416386
                  Another one who has never had one or felt the need for one.
                  I do have a 5C chuck and 4 or 5 square collets but even then they don't get used that often, if I want something with a square head I'm more likely to machine from round and then mill the head in the spin indexer. Most small square stock has rather soft corners for my liking so I mill them to get a crisp part.
                  #416388
                  Plasma
                    @plasma
                    Hi Roger.
                    I have a large self centreing 4 jaw and I use it a lot.
                    It's better for thin walled jobs and the extra capacity is useful for so many things without the faff of an independent chuck.
                    As well as the already mentioned square stock use I would not be without mine, it sits on one lathe with a 3 jaw or collet chuck on the other.
                    Regards mick
                    #416389
                    mechman48
                      @mechman48
                      I've often thought it would be a 'Nice to have' item ; but then again I've asked myself 'do I really NEED it?. I would go for something more beneficial… collet set, DRO's etc
                      George.
                      #416394
                      Former Member
                        @formermember19781
                        #416395
                        HasBean
                          @hasbean
                          I would appear to be in the minority.
                          I use mine a lot, in fact I can't remeber the last time I took it off the lathe except for using my ER32 collet chuck. It's only a 4" job but is consistently accurate to within 0.03mm, more than good enough for my meagre skills blush & I've never noticed any issues with holding round stock.
                          Paul
                          #416404
                          Bazyle
                            @bazyle
                            Perhaps a double 2 jaw would be a better invention. Ie two opposite jaws linked so they centre up one plane then the other two jaws linked to handle the 90 degree faces. That way rectangular stock, round and square could all be held with assured contract on all jaws.
                            Edited By Bazyle on 27/06/2019 12:47:01
                            #416407
                            not done it yet
                              @notdoneityet
                              Posted by HasBean on 27/06/2019 12:00:46:
                              Paul
                              Many three jaw self centering chucks can be just as accurate, or possibly better than that
                              Think about a 40mm aluminium ‘round’ bar (topical) that is only 39mm in one plane. When the two jaws are tight on the 40, the other two might still have 1mm to take up. Not good, when both pairs of jaws are mechanically interlocked!
                              I put one on my rotary table and have regretted it. There was one on my lathe, but I prefer the usual three jaw or the four jaw independent. The independent one probably gets most use.
                              The self centering 4 jaw is rather better than 0.03mm runout, but I would still not want to re-chuck an already machined item in it (which is where you might notice it?). I avoid using it for anything that may not be perfectly round – it might only be gripping on two jaws!
                              I would recommend the OP to spend his vouchers on something else (ER collet chuck, maybe).
                              #416422
                              Clive Foster
                                @clivefoster55965
                                Very much an "if you need it you will know" thing. Although it has its advantages in certain jobs its not really a general purpose device.
                                If you are wondering, shall I – shan't I, you don't need it.
                                Over the years I've bought a fair bit of stuff after the shall I – shan't I debate most of which ended up as cupboard queens and bragging rights. When it takes 25 years between purchase and "I couldn't have managed without it" you are probably doing something wrong. Especially in that case as if I'd not had it I'm not have been lumbered with the job which turned out mega grief!
                                #416427
                                MalcB
                                  @malcb52554
                                  I have an RDG SC 4 jaw for my Harrison M300.
                                  As others have said its a luxury unless you have an abundance of chucks and frequent need for square bar stock.
                                  I have 3 x 3 jaws, 3 x ind 4 jaws and 2 x collet set ups ( 1 x ER40 and 1 x Pratt ) all gained at various times etc.
                                  They do make a good backup for round stock to the 3 jaw and the RDG one i have is excellent on running true.
                                  My advice ( again as others mention ) is to save further for a good collet setup first.
                                  #416429
                                  Chris Evans 6
                                    @chrisevans6
                                    I would put the money towards a 5C chuck and collets. 80% of my work is in collets.
                                    #416430
                                    Baz
                                      @baz89810
                                      I have one, used it a couple of times and now it holds the workshop door open. For it to be any use the work must be square to within .001”, if one side is larger than the other it will only grip on two jaws and rock on the other two.
                                      #416435
                                      roy entwistle
                                        @royentwistle24699
                                        Note also that not all square stock is square
                                        Roy
                                        #416438
                                        HasBean
                                          @hasbean
                                          Posted by MalcB on 27/06/2019 14:31:08:
                                          I agree, my ER32 collet set would definately be higher up on the list than the 4Jaw SC if I was buying again.
                                          Paul
                                          #416454
                                          Brian Wood
                                            @brianwood45127
                                            Roger,
                                            Clearly opinion is divided.
                                            I found a 4J self centreing Pratt chuck on the RDG stand at the last Harrogate show and after I put the fitting right on it's backplate [ it was at least 1 mm in error] it has proved to be truly accurate and I prefer to use it for most work now.
                                            It was almost brand new at the time of purchase, the previous owner must have been deeply disappointed with it's performance, all down of course to a sloppy job he made of fitting
                                            So, your choice really
                                            #416458
                                            Hollowpoint
                                              @hollowpoint
                                              I like them and prefer them to 3 jaw chucks. That said a collet chuck would be much higher up on my list.
                                              If you're just looking to spend some money and treat yourself one of the best upgrades is a QCTP without doubt. DRO scales are another time saver as is the often overlooked tailstock turret.
                                              #416459
                                              jimmy b
                                                @jimmyb
                                                I bought one last year (and three sets of soft jaws…..). Its been useful, but to be honest, I could live without it!
                                                But, if you need one, you need one.
                                                Jim
                                                #416460
                                                FatWelshBoy
                                                  @fatwelshboy
                                                  I'd buy something else being as you already have a independent 4 jaw chuck. I've an ER32 collect chuck for my lathe and love it, gets a fair bit of use. I also have a really, really nice independent 4 jaw that's a tad big for my lathe so will be downsizing. Once I've done that I can't see my using my 3 jaw on the lathe again. I've currently got the poor mans DRO of a dial indicator and caliper on the lathe but really tempted to go for a proper DRO after having a play on a lathe with one fitted, really makes things so much easier and quicker. I'd definitely consider a DRO if I was you.
                                                  #416461
                                                  Chris Gunn
                                                    @chrisgunn36534
                                                    I have one and find it handy making clevises and so on, it will grip round of course, but not hexagon. A lot will depend on what you make, if you work with square a lot, then it will save loads of time faffing about with an independent jaw chuck. I often use mine to make rod ends that need to be rectangular in section, I do all the turning and cross drillin and so on, then mill the square to a rectangle.
                                                    Chris Gunn
                                                    #416469
                                                    Vic
                                                      @vic
                                                      I’ve often thought a 4 jaw SC would be very useful.
