What is this tool?
What is this tool?
Home › Forums › General Questions › What is this tool?
Viewing 15 posts - 1 through 15 (of 15 total)
  • #120508
    Chris123
      @chris123
      I bought this as I had assumed it was a vertcial mill facing tool, it's just arrived and takes inserts up the sides as well? So I'm not really sure what it's for.
      Also, I think it'll still be ok to use as a facing tool, so where is the best place to search for an insert to fit it?
      Thanks.
      #22637
      Chris123
        @chris123
        #120509
        MichaelR
          @michaelr
          Is it a Helical mill for contouring and slotting, tips could be a special type.
          #120510
          Raymond Anderson
            @raymondanderson34407
            Chris,
            It,s a Helical shell mill. It would be a small fortune to load it up with inserts and would take a lot of rigidity and horse power to use it effectively, not exactly a model engineering type tool.
            Raymond.
            #120511
            Raymond Anderson
              Chris,
              Forgot to say look for the makers name and you should also find the model number
              if you can see them, then you only need to either contact the maker with the info or, get it from their catalogue [usually able to download]
              #120512
              Mike Poole
                @mikepoole82104
                Cutwel list this holder and supply inserts. It is a Korloy Alpha mill and takes APMT11T3 inserts looks like they are around £5 each so about £135 to fully populate it.
                Edited By Michael Poole on 23/05/2013 20:09:52
                #120537
                Ian S C
                  @iansc
                  I'd use it with 3 cutters on the end, you could use 6 if you want to, and ignor the ones up the sides.
                  Ian S C
                  #120539
                  Clive Hartland
                    @clivehartland94829
                    This looks like a cutter that is used at some high speed for maximum metal removing on tough steels, you would need a rigid machine with some large hp motor to drive it.
                    #120544
                    Raymond Anderson
                      Chris / Michael,
                      I really don,t think it's a Korloy Alpha mill as Korloy shell mills are a silver grey colour, this one looks the more normal black . I have quite a few Korloy ones and none are this colour I also have a few Sandvik and Walter ones and they are black. It would be best to look for the makers name or a series of numbers and google it. Could you put up a photo of the insert seat ,as that would also help .
                      Raymond.
                      #120546
                      S.D.L.
                        @s-d-l
                        The referance wisible in the top photo is AMCM2100M which googles to a Korloy part referance.
                        Steve
                        #120548
                        jim’
                          @jim11037
                          Commonly called a porcupine cutter
                          #120549
                          Raymond Anderson
                            Steve,
                            I stand corrected, after blowing up the photo I saw the Korloy logo. It's the first time I have seen black bodies on Korloy mills, well spotted.
                            Raymond.
                            #120619
                            Chris123
                              @chris123
                              Thansk for the replies, I'm not getting email notifications for some reason?!
                              These are pictures of where the insert fits.
                              Michael: Where did you see the inserts for £5 I can't find them on that website.
                              Ian: Yes, I was planning on using just the end ones as a face mill.
                              #120640
                              Mike Poole
                                @mikepoole82104
                                try here for inserts for various materials
                                http://www.cutweltools.co.uk/files/ww/IM%20B25-32.pdf
                                and here for info on the body
                                mike
                                Edited By Michael Poole on 25/05/2013 23:57:01
                                Edited By Michael Poole on 25/05/2013 23:57:55
                                #120710
                                Chris123
                                  @chris123
                                  Thanks
