What do I use to run my oscillating engine?
Home › Forums › Help and Assistance! (Offered or Wanted) › What do I use to run my oscillating engine?
  • #243187
    Mark Williams 21
      @markwilliams21
      Hi,
      When I complete my oscillating engine I won't have a boiler or anything live steam wise to run it on so obviously I will be running it on compressed air, so my question is what do people use for this? Mini-air compressor, aquarium air pump? Any suggestions please
      Many Thanks
      #32723
      Mark Williams 21
        @markwilliams21
        #243188
        Peter Krogh
          @peterkrogh76576
          Aquarium pumps may not do the job; not enough pressure. Air brush compressors will run most small engines but may cycle frequently depending upon the size of the engine and the size of the air receiver. I know guys who use the mini to fill an air tank of some sort so they can run quite a while….
          Pete
          #243189
          Mark Williams 21
            @markwilliams21
            Ok so the best option is buy a airbrush compressor and make/purchase a air tank for it while I build a steam boiler?
            #243193
            Peter Krogh
              @peterkrogh76576
              Many auto parts stores sell air tanks to transport air to locations without compressors. Anywhere from about 2 gallons to 5 gallons size.
              Air brushes are very nice to have when painting models.
              Pete
              #243195
              julian atkins
                @julianatkins58923
                For testing locomotive chassis I run them on air (not too long) but use Singer sewing machine oil which doesnt break down under condensate on air.
                Cheers,
                Julian
                #243201
                Paul Lousick
                  @paullousick59116
                  Auto parts stores also sell small compressors for inflating car wheels.
                  #243209
                  John Reese
                    @johnreese12848
                    I used a propane cylinder for a hand held torch as an air tank on my airbrush compressor to keep it from short cycling.
                    #243210
                    Thor 🇳🇴
                      @thor
                      Hi Mark,
                      I too use an air brush compressor for running my small oscillators. If your oscillator has little friction they don't need much pressure to run. For a simple to make low-pressure boiler see here.
                      Thor
                      #243212
                      Paul Lousick
                        @paullousick59116
                        See previous post about powering small steam engines
                        Edited By Paul Lousick on 18/06/2016 06:28:11
                        #243213
                        Mark Williams 21
                          @markwilliams21
                          Morning gents, thanks for the advice, I've had a quick look online and an airbrush kit that contains a compressor with tank is only about 40-50 quid so I'll probably get one ordered today and as Peter said it'll be nice to have anyway for painting my future models 👍🏻
                          Mark 😎
                          #243215
                          john carruthers
                            @johncarruthers46255
                            Old fridge compressor? they are very quiet.
                            They don't produce a huge volume but quite a good pressure eventually.
                            I tested my first wobbler on the coffee maker steam outlet.
                            Edited By john carruthers on 18/06/2016 07:44:17
                            #243217
                            Howi
                              @howi
                              There are two ttypes of airbrush compressor, the piston type which produces high pressure but low volume and the diaphragm type which produces larger volume but lower pressure.
                              This second type is better for small engines.
                              #243224
                                Do you have a cappuccino machine? You can run a small engine for a few minutes using a silicone tube on the frother (don't let your coffee addicted better half catch you though).
                                Martin Whittle
                                  @martinwhittle67411
                                  On my Reeves Master engine, I made an inlet 'manifold' using a schrader tyre valve body as the inlet connector, silver soldered into a brass block. It runs well off a compressor, but will also run (less evenly!) using a bicycle pump smiley.
                                  Martin
                                  #243246
                                  mechman48
                                    @mechman48
                                    I initially used a airbrush compressor with tank myself, the only fault is that it cycles frequently which is common for this type; I also have a larger compressor bought from M/Mart on one of their VAT free days, obviously this provides a larger volume of air, so it's dependent on your budget what you get.
                                    George.
                                    Edited By mechman48 on 18/06/2016 11:18:28
                                    #243252
                                    Ian S C
                                      @iansc
                                      I have a small medical compressor(30psi) that works well on small steam engines, it won't handle a Stuart Turner S9, double acting 1 1/2" x ! 1/2". For a quick test run I have a 5L garden spray pump, and that will run any of my little wobblers.
                                      #243257
                                      Hopper
                                        @hopper
                                        You can always make a simple boiler too, by silver soldering a couple of end plugs in a six inch length of 1.5" copper or brass pipe with suitable small pipe fittings for water fill and steam outlet. A cough drop tin full of cotton wool soaked in methylated spirits is all you need for a burner.
                                        #243286
                                        Mark Williams 21
                                          @markwilliams21
                                          Posted by Neil Wyatt on 18/06/2016 09:51:13:
                                          You trying to get me divorced? Lol
                                          #243287
                                          Mark Williams 21
                                            @markwilliams21
                                            the plans for the oscillator I've all but finished also has plans for a simple boiler, I think that will have to be my next project.
                                            Thanks for all the advice 😄
                                            #243330
                                              Being a cheapskate I've used a car tyre foot pump with a plastic lemonade bottle as receiver to turn a small engine. Make two nozzles to fit through the bottle cap and connect between pump and engine with aquarium tubing. Cheap and cheerful and you get a real sense of how much work you have to do to keep a even small engine running.
                                              I've not managed to burst a bottle yet. Blood vessels yes – exercise isn't my thing!
                                              Robert Dodds
                                                @robertdodds43397
                                                Anybody tried one of the hand held steam cleaners?.Various websites sell for under £25 and you get 3bar pressure off them Come with built in safety. valve. AND you will know where to find it if it goes missing.
                                                Bob D
