Weight of Dore Westbury mill/drill
Home › Forums › Manual machine tools › Weight of Dore Westbury mill/drill
  • #504402
    metalfettler
      @metalfettler
      Hi guys,
      Having just wrestled with my D-W mill I had to resort to splitting the head/motor and table/base lumps. It seemed heavier than my Myford S7, but memory of traumas soon fades.
      Since it was a struggle for self and son I am interested in having some idea of the dead weight of the unit. I have scoured the interweb but nowhere is weight detailed; I have the full building manual but no joy there.
      The mill is now sitting on the end of a Clarke/MM sheet-iron bench having bowed an MDF desk. Some years ago it sat quite happily on a Warco mini bench with thin-gauge dexion legs so now hoping for a stable installation.
      I know this isn't in the league of the wondrous feats described by other machine movers but I am disappointed that the passage of time has removed me from the days when I would switch car engines in a trice.
      Regards, Les
      #14067
      metalfettler
        @metalfettler
        #504409
        not done it yet
          @notdoneityet
          Leslie,
          If we knew the whereabouts of your residence (profile?) someone might offer a load cell for you to weigh it – if you could heave it by a pulley system or similar. Mine will weigh up to 250kg, so should be more than adequate.
          Edited By not done it yet on 30/10/2020 19:01:52
          #504414
          Brian Wood
            @brianwood45127
            Les,
            It is a sad reflection on the passage of time I'm afraid. When I moved mine from the Yorkshire Dales to the current address near Thirsk I packed it and the other machines in crates I had made for the move.
            I couldn't do it again now even if my life depended on it! At a guess I would suggest 150 kg all up
            Regards Brian
            #504513
            Kettrinboy
              @kettrinboy
              I would say my Mk1 weighs around 80/90 Kg all up , but as they are a simple machine to strip down to main components they are easier than most small mills to move around.
              regards Geoff
