Washer size!
Washer size!
Home › Forums › Beginners questions › Washer size!
  • #650341
    Margaret Trelawny
      @margarettrelawny34058
      Hello again everyone – I need your help again please!
      I am trying to source a 13.5mm OD washer. Spalding don’t have them – can anyone suggest an imperial equivalent please?
      It needs to fit snugly into a tube.
      many thanks
      Margaret
      #11507
      Margaret Trelawny
        #650349
        Nicholas Farr
          @nicholasfarr14254
          Hi Margaret, washer sizes are normally designated by their ID and I doubt you'll find any advertised as 13.5mm, if you mean ID, then a 1/2" one might be about the right size, but you may just have to file it to fit.
          Regards Nick.
          #650351
          Margaret Trelawny
            Thanks Nick.
            I think we may end up turning one from a piece of brass.
            #650355
            Bill Phinn
              @billphinn90025
              M6 Form C Washers [BS 4320] have an OD of 14mm. You could easily spin one of these in a drill chuck against abrasive paper to get it down to the required OD.
              You don't say what ID you need, however.
              #650380
              Margaret Trelawny
                Thanks Bill. That’s a good suggestion.
                ID doesn’t matter really.
                many thanks
                Margaret
                #650493
                Grizzly bear
                  @grizzlybear
                  Hi Margaret,
                  Can you tell us what you are constructing/repairing/fabricating?
                  It makes life so much easier all around.
                  If it's secret, then I will respect that.
                  Bear……….
