Warco WM250V Screwcutting
Home › Forums › Help and Assistance! (Offered or Wanted) › Warco WM250V Screwcutting
Viewing 23 posts - 1 through 23 (of 23 total)
  • #587642
    Andrew Douglas 1
      @andrewdouglas1
      Hi all,
      Im hoping someone on here can help me out. I have had a Warco 250V for about 3 months and just getting on to screwcutting.
      I have set up for 1.25 pitch with a 30 tooth at the top a 75 paired with 80 tooth in the middle and a 60 tooth on the input to gearbox, gearbox set to A , all as per the table & manual. The scratch pass creates a perfect 1.25 pitch so all good.
      The problem comes when i disengage the half nut and use the TDi to pick up the thread again, the label on the machine says to used TDI positions 1,6 so I am using 1 and waiting for it to come back round again. The tool does not pick up the thread and misses by a small amount eaxch time thus taking the crest off the partially ciut previous thread.
      Any ideas much appreciated.
      I know i can just leave the nut engaged and reverse the lathe after backing off the tool so as to get back to the statrt but would really like ton use the TDI as idid on my previous machine.
      #33983
      Andrew Douglas 1
        @andrewdouglas1
        Problems with TDI
        #587660
          First question would be is it a metric or imperial leadscrew?
          Secondly ensure the threading indicator is fully engaged with the lead screw and the dial on the top screwed on tightly.
          #587662
          DC31k
            @dc31k
            Following on as question 2, from Jason's initial one:
            2) IF it is a metric leadscrew, what is its pitch?
            3) How many teeth are on the gear of the thread dial indicator which meshes with the leadscrew?
            Please view from 0:50 to 1:10 in this video:
            Edited By DC31k on 01/03/2022 08:20:51
            #587663
            Martin Connelly
              @martinconnelly55370
              To add to what DC31k has asked, how far do you have to move the saddle to rotate the thread dial one or five revolutions? Five is better for accuracy. A typical inch based one will move an exact number of inches per revolution, I would expect 2" but a metric one will move a multiple of a metric pitch so 50mm is a possibility. Doing 5 revolutions will help differentiate between the two.
              Martin C
              Edited By Martin Connelly on 01/03/2022 08:17:34
              #587688
                Assuming this is a metric WM250V, and the lead-screw is the same as my metric WM280, then one of Andrew's gears is incorrect. Where H is a spacer, he has:
                H-30 (30 engages spindle gear)
                75-80 (75 on outside)
                60-H ( 60 drives gearbox on 'A' )
                Andrew's gears aren't in my list of combinations that do 1.25 (20.32tpi) on a WM280:
                85 60 50 80 5/4 1.25 20.32
                30 80 50 60 5/4 1.25 20.32 (On front panel)
                75 80 50 60 5/4 1.25 20.32
                65 80 50 60 5/4 1.25 20.32
                75 60 50 80 5/4 1.25 20.32
                65 60 50 80 5/4 1.25 20.32
                60 80 50 60 5/4 1.25 20.32
                30 60 50 80 5/4 1.25 20.32
                20 60 50 80 5/4 1.25 20.32
                85 80 50 60 5/4 1.25 20.32
                70 60 50 80 5/4 1.25 20.32
                45 80 50 60 5/4 1.25 20.32
                60 60 50 80 5/4 1.25 20.32
                70 80 50 60 5/4 1.25 20.32
                45 60 50 80 5/4 1.25 20.32
                Is Andrew's 75 correct? Try:
                H-30
                50-80 (same as Andrew except 50, not 75)
                60-H
                I don't think it's a metric/dial counter problem because my metric dial counter works on this pitch. It allows 1-6 rather than 1,6 (i.e engage half-nuts on any mark rather than 1 or 6 only) but Andrew engaging on 1 only should be fine.
                I cut this 1.0 pitch thread last week and the dial indicator didn't work at all. It's a mess:
                Double operator error: I misread the gear combination off the front of the lathe AND the number of teeth stamped on one of the gears. (Iffy eyesight and the gears are lightly stamped) Had me going for longer than it should because I often cut 1.0 pitch threads and was convinced the banjo was correct.
                Check everything.
                Edited By SillyOldDuffer on 01/03/2022 11:53:06
                #587692
                Hopper
                  @hopper
                  Not familiar with your lathe but some metric lathes have different gears to put on the bottom of the TDI to work on different pitches. Worth checking on yours perhaps.
                  #587698
                    The metric 250s have a 3mm pitch, imperial 8tpi leadscrews
                    Fixed 40T on the spindle that will be driving the 30T, A on the box is straight through 1:1
                    As SOD says I can't make that gear train work for 1.25mm pitch
                    Edited By JasonB on 01/03/2022 13:03:26
                    #587723
                    Mick B1
                      @mickb1
                      Mine's a metric WM250V and it has a 2mm leadscrew pitch.
                      Most of the threads I cut are Imperial for the steam railway, and I just leave the nut engaged and reverse back to the thread start. It's simpler and safer.
                      In my early days with this lathe I played about with the chasing dial on both metric and imperial threads, trying to get some sense out of it, but decided life was just too short. In any case, my experience with its predecessor, a Myford Speed 10, led me to think you can waste just as much time waiting for the lines to come round the dial as you would reversing back.
                      I've wondered if chasing dials might be a fossil feature, from the time when reversing lathes was more time-consuming than it is now, if it was possible at all – and manufacturers just put 'em on 'cos they've always been there.
                      Edited By Mick B1 on 01/03/2022 18:08:00
                      #587724
                        Thanks Mick, looks like the latest V has a 2mm, earlier ones were certainly 3mm. Out of interest what is the gear train shown on your machine for 1.25mm?
                        #587726
                        Mick B1
                          @mickb1
                          Posted by JasonB on 01/03/2022 18:11:13:
                          I've got:-
                          H 30
                          75 80
                          60 H
                          and the pitches are C=0.62, A=1.25, B=2.5 for the feed settings.
                          Incidentally, I notice the manual advises to leave the nut engaged, and the chasing dial doesn't appear in the photo on the front of the manual or in the parts lists!
                          It's just a sales gimmick IMO.
                          Edited By Mick B1 on 01/03/2022 18:54:29
                          #587735
                          Andrew Douglas 1
                            @andrewdouglas1
                            HI All
                            well firstly thank you for all your responses , i did not expect so many so quickly.
                            toi answer some questions
                            1/ the leadscrew is definately 2mm pitch (checked with thread gauge and eyepiece)
                            2/ The TDI gear is 48 teeth and the divisons on the dial ar 12 (odd numbered).
                            The changegears
                            H 30
                            75 80
                            60 H
                            and gear box set to A (1.25)
                            The scratch thread is 1.25 so nothing wrong with the changegears.
                            The problem is picking up th thread with the TDI using the indicated positions 1, 6 , the thread is NOT picked up and i end up removing the crests of the already cut threads.
                            Any help appreaciated
                            #587740
                            Tony Pratt 1
                              @tonypratt1
                              Guess you will have to leave the half nuts engaged at all times, I just had a Google on cutting metric threads on a metric lathe using a TDI & apparently it may not be straightforward, others on here may be able to elaborate I only just had a quick skim read on the subject.
                              Tony
                              Edited By Tony Pratt 1 on 01/03/2022 20:28:25
                              #587746
                              Tony Pratt 1
                                @tonypratt1
                                If anyone has a few hours to waste, try this link, well nearly a linksad
                                https://bbs.homeshopmachinist.net/forum/general/46983  -why-doesn-t-a-thread-dial-work-with-metric
                                Tony
                                Edited By Tony Pratt 1 on 01/03/2022 20:44:20
                                Edited By Tony Pratt 1 on 01/03/2022 20:45:42
                                #587749
                                Mick B1
                                  @mickb1
                                  My manual contains no reference to or picture of the chasing dial, nor is there any label indicating how it should be used. IIRC I even tried engaging at the same marking each time, and still found it didn't pitch in accurately.
                                  I've taken mine out of leadscrew mesh, and I don't miss it.
                                  #587766
                                  Martin Connelly
                                    You need a gear with 40 teeth on the TDI. This will allow you to go 2mm x 20 = 40mm per half revolution which is 32 pitches of your thread. This is why metric TDI systems come with multiple gears for the TDI.
                                    You could also go 1/4 turn of the TDI for 16 pitches (20mm) with this 40 tooth gear.
                                    To use the 48 tooth gear on the TDI you would have to move 5 of your 12 divisions or multiples of 5 such as 10 or 15 which would move you in 20mm steps (16 pitches of 1.25mm). This is likely to be error prone which is why the 40 tooth gear is the best option.
                                    Martin C
                                    #587804
                                    DC31k
                                      @dc31k
                                      Martin Cleeve's book, 'Screwcutting in the lathe' covers the thread dial indicators very well (Section 5 entitled 'problems and analysis of repeat pick up'. It is concise, correct and unbiased. It is prudent to read the US forum cited above with some wariness as many of the discussions there are motivated by a desire to denigrate the metric system
                                      Think of the thread dial indicator as a counter – the fact that it is gear-shaped is not really relevant. It is no more sophisticated that what you see if you Google 'click counter'. Every 'tick' of the counter, instead of registering someone's entrance into an event, counts one leadscrew pitch (2mm in your case).
                                      So, if the gear has 48 teeth, it will measure 96mm per rotation. The dial that is mounted on top of that gear will not have 48 graduations on it (corresponding to one graduation per tooth) as that would be confusing. Instead, it has 12 graduations (corresponding to 4 gear teeth). Thus, each graduation on your dial will measure 96/12 = 8mm.
                                      For the thread dial indicator to be of any use to you, the distance it measures in one revolution has to equal an integer number of pitches of the thread you are cutting. If you are cutting 1.25mm pitch, 96/1.25, or (96×4)/5 is not an integer, so the dial is no use for that thread pitch.
                                      I am assuming the threading chart on the lathe in the Youtube video above is the same as your own. In which case, your indicator will be useful for 0.2, 0.4, 0.8, 0.3, 0.6, 1.2, 0.5, 1.0, 2.0, 0.75, 1.5, 3.0mm pitches. That is 12 out of the 18 possible ones*. It will not be any use for 0.625, 1.25, 2.5, 0.875, 1.75, 3.5mm pitches.
                                      Martin suggests a 40t gear above, and for the 1.25mm column, that will work. But more importantly than a specific number of teeth, what it is necessary to understand is that any gear that has teeth that are a multiple of 5 will do. Similarly, for the 1.75mm column, a gear that has teeth that are a multiple of 7 will be needed. The disadvantage of the 40t gear suggested is that it will not be useful for 0.3, 0.6, 1.2, 0.75, 1.5, 3.0mm pitches as those need a gear that divides by 3, which 40t does not. The other columns need a gear with an even number of teeth, which the 40t does have so it can be also used for those ones.
                                      If you want one gear that will do all the missing threads that the standard 48t will not do, a 35t one would do both columns, but it also has the disadvantage that it will need two different dials for the top of it – one divided into 5 and the other divided into 7.
                                      So, the thing to take away from this is that no single gear will work with all metric threads. What you can do is assess which threads you will be cutting most often and choose a gear that maximises efficiency for those threads.
                                      * We could perhaps discuss how many of the 'possibles' are actually useful – I do not have many screws with 0.3, 0.6 or 1.2mm pitches.
                                      #588068
                                      Andrew Douglas 1
                                        @andrewdouglas1
                                        Thanks all once again for your help.
                                        So it looks like i need a 40 tooth and a 28 tooth as well as the 48 tooth.
                                        The stated Module is 0.64 and i have searched high and low to find 28 & 40 tooth gears with such a Module.
                                        I find that the nearest DP is 40 but again i cannot find any gears to suit
                                        My next thiought was to cut a couple of gears and i can fend the neccessary involute cutters however most seem to be 14.5 degree PA as opposed to 20. I am guessing my 2mm pitch leadscrew being metric will need 20 degreePA or does it matter ?
                                        Once again i value all your help and input
                                        #588085
                                        Martin Connelly
                                          Since you are running against a 60° thread with a flank angle of 30° a theoretical gear to suit would have this as the pressure angle. There is no real power transmission taking place so even with a mismatched pressure angle there will be minimal wear. Just buy a plastic gear that is 40DP and make it fit and it will do the job. You may not even match the helix angle when they meshing
                                          Martin C
                                          #588088
                                          Hopper
                                            @hopper
                                            Posted by Andrew Douglas 1 on 04/03/2022 10:03:45:
                                            There is no need for the gears on the bottom of the TDI to be an exactly perfect involute gear tooth profile. They are a straight cut gear engaging with a thread (worm) so will be in point contact only, and loading on the gear is as close to zero as it's possible to get. And pressure angle likewise is not so important.
                                            So probably 0.6 module or 40DP might work ok providing the gear is not jammed up hard against the screw. Or cut your own with whatever the nearest cutter you have. They can be made from Delrin or from 2mm thick brass or aluminium plate. Or you could make a disc with holes drilled around the periphery and small pins stuck in the holes for that matter. All they are is a place holder, or FPO as they say, for positioning only.
                                            Edited By Hopper on 04/03/2022 10:41:59
                                            #588113
                                            DC31k
                                              @dc31k
                                              Something else to take into consideration before selecitng a tooth count is the space available. A 28t gear will be approximately 50% of the diameter of the existing 48t one, so you might have to do some gymnastics with the indicator body in order for it to mesh with the leadscrew.
                                              If the existing gear is 48t, a nearby one containing a factor of 5 would be 45 or 50 (45 good as it also contains 3; 50 good as it also contains 2). 49t is near 48t and contains the 7 you need, but its other factor is another 7 so it will be a one trick pony. If 42 will fit, that might do as it has 2, 3 and 7.
                                              #588136
                                                Not necessarily, because a Turns Dial Indicator isn't needed to cut threads. It's a convenience rather than essential.
                                                For reasons related to the difference between Turns per Inch and Pitch when defining threads:
                                                • Imperial Lathe producing Turns per Inch threads – TDI straightforward.
                                                • Imperial Lathe producing pitch threads – TDI useless.
                                                • Metric Lathe producing Pitch threads – TDI limited or fussy: several gears needed to cover all pitches
                                                • Metric Lathe producing Imperial threads – TDI useless.
                                                So unless you're a pure Imperial shop, it's not unusual to find the TDI is of limited value.
                                                The usual alternative is to leave the half-nuts engaged all the time. The thread is cut in the normal way, except the lathe is stopped at the end, the cutter retracted, and then reversed out under power. Once clear of the job, the cutter is advanced to take the next cut, and driven forward again. Repeat until the thread is finished.
                                                An important advantage of not disengaging the half-nuts is the system works for both pitch and TPI threads and the operator can't lose register due to getting the TDI wrong or reacting too slowly.
                                                A useful variant on lathes with fine speed control in both forward and reverse is they can cut threads away from the chuck in reverse. This removes the risk of crashing accidentally into the chuck and allows threads to be cut safely at high speeds. My preferred method and the WM250 is suitable.
                                                I'm still pondering the original question but it looks as if DC31k has got there first. His sums suggest Andrew's TDI doesn't cover 1.25, in which case the lathe may be labelled wrongly. Or possibly the TDI needs a different gear fitted, which is lost. My mini-lathe came with 3 TDI gears, but my WM280 only had one. I haven't tested the WM280's TDI label is correct on all settings. It claims 0,2, 0.3, 0.4, 0.5, 0.75, 1.0, 1.25, 2, 2.5 and 3.0. Note 0.35, 0.45, 0.6, 1,2, and 1.75 are missing. (Also that the change gears provided only produce poor approximations of 0.35 and 0.45. Not a problem because I always tap and die small threads.)
                                                Howard Lewis
                                                  @howardlewis46836
                                                  My lathe has a 3 mm pitch Leadscrew.
                                                  I always leave the half nuts engaged, when cutting either cutting Metric or Imperial threads, and proceed as above, retracting,
                                                  reversing far enough to ensure that the backlash has been taken out before running forward for the next cut.
                                                  The one time that I tried using the TDI, I had problems, so the half nuts are only disengaged when the job is finished.
                                                  Howard.
