Warco Major Mill
Warco Major Mill
Home › Forums › Manual machine tools › Warco Major Mill
  • #498318
    Derek cottiss
      @derekcottiss41883
      im about to take possetion of a major mill drill s/h
      would like to add power feed and a dro any suggestions what to look for and from who ?
      thank you
      #14033
      Derek cottiss
        @derekcottiss41883
        #498327
        Nicholas Farr
          @nicholasfarr14254
          Hi Derek, you can get a power feed at power feed Warco. Just scroll through the accessories
          Regards Nick.
          Edited By Nicholas Farr on 28/09/2020 18:05:31
          #498330
          Derek cottiss
            @derekcottiss41883
            Posted by Nicholas Farr on 28/09/2020 18:02:49:
            Regards Nick.
            saw that just wondered if there were better /cheaper optioms as if i buy it all from Waco its more than the mill …
            #498332
            Howard Lewis
              @howardlewis46836
              Have not got power feed because, from memory, are only supplied in 110 Volt form and the unit and the 240 / 110 volt transformer are quite a costly combination.
              #498336
              John Rudd
                @johnrudd16576
                Go to your friendly local electrical wholesaler and buy a 240/110 control transformer rated at 200VA…..
                if you can wire a 13A plug, you can wire up the transformer easy enough….
                I paid around £30 for mine then another £20 for a suitable enclosure….still cheaper than buying from 'tool merchants'
                No doubt other members will share their pearls of wisdom…
                #498339
                Nicholas Farr
                  @nicholasfarr14254
                  Hi Derek, sorry I don't know anything else that may be suitable, may be worth looking around second hand places.
                  Regards Nick.
                  #498361
                  Packmule
                    @packmule
                    Hi Derek,
                    just about to undertake this project. Bought parts form that well known auction site total cost around £70
                    I know someone has has built this and he's very pleased with the result.
                    Hope it helps,
                    Bob
                    Power feed
                    #498380
                    Derek cottiss
                      @derekcottiss41883
                      Posted by John Rudd on 28/09/2020 18:21:43:
                      what did you use as the motor ?
                      #498383
                      John Rudd
                        @johnrudd16576
                        I bought a proprietry unit that bolted to the mill table, as it was a 110v unit, it need a 110v supply, hence the cheaper route of buying a control transformer rather than a 'proprietry' unit as supplied by the 'tool merchants'…
                        #498397
                        Packmule
                          @packmule
                          I bought a 12v 600rpm motor.
