Two queries please
Two queries please
Home › Forums › Workshop Tools and Tooling › Two queries please
  • #476166
    MC Black 2
      @mcblack2
      I wonder if one or more of the wise subscribers can provide pointers about two things:
      Firstly, can anybody kindly suggest where I might purchased a 7.3mm HSS drill where the postage isn't three times the cost of the drill.
      It's for a particular job – creating a hole to tap for M8 x 1.0mm thread.
      Secondly, I'm buying various drill bits for different jobs and need an inexpensive empty 6.0mm to 10mm x 0.1mm box to keep them in.
      Any suggestions, please?
      Very many thanks for your anticipated assistance.
      MC Black
      #19785
      MC Black 2
        @mcblack2
        #476172
        Martin Connelly
          @martinconnelly55370
          Standard tapping drill for metric threads is size minus pitch. That gives 7mm for your thread, do you want to go up to 7.3mm for a reason because 7mm is probably easier to find.
          Your question regarding a box for drills has come up in the past. It is probably easier to make your own stand  than to buy an empty box. You could buy a set, the drills in the set I have are good quality. If they break or wear or fail to drill what you want just replace the ones you use up with good quality ones as required.
          Martin C
          Edited By Martin Connelly on 30/05/2020 18:30:22
          #476190
          not done it yet
            @notdoneityet
            HERE is one previous thread on this subject. Likely lots more.
            #476192
            Former Member
              @formermember32069
              #476360
              larry phelan 1
                @larryphelan1
                You might also try Drills UK.
                I have bought from them several times and found them good to deal with.
