Tom Rolt cylinders
Tom Rolt cylinders
Home › Forums › Beginners questions › Tom Rolt cylinders
  • #437435
    Former Member
      @formermember19781
      #9937
      Former Member
        @formermember19781
        #437488
        Nigel Bennett
          @nigelbennett69913
          Admittedly mine's 3.1/2"G, so I had to do my own thing, but I went for a brass fabrication with cast iron liners. Fabricating from steel with CI liners would be another option. Much cheaper to fabricate!
          Provided you ensure it's well lubricated after a run, CI is the way to go – especially as you can then use CI piston rings in both the main cylinders and the piston valves.
          #437493
          Former Member
            @formermember19781
