To Grind or Not to Grind – that is the question
Home › Forums › General Questions › To Grind or Not to Grind – that is the question
  • #22476
    Anna Jablonska
      @annajablonska79888
      Should I regrind the bed ??
      #112579
      Anna Jablonska
        @annajablonska79888
        Apologies to Shakespeare for using a part of his literary talents, but in fact this is my quandry – re-grind the bed, or not….
        Why ?
        1. Lathe is disassembled.
        2. Needs a new paint job anyway.
        3. It has wear of 0.20mm (8 thou's or thereabouts) vs nominal shear height at the chuck end….0.07mm (2thou and a bit) at the tailstock end.
        4. Top of ways are worn by 1 1/2 thou vs headstock….ie they are that much lower….
        5 Shear widths are within 1 thou of nominal….
        So my dear friends and colleagues – what would you do in my shoes…?
        Hugs from a snowy Poland…
        A
        #112590
        KWIL
          @kwil
          You should also look at the underside of the carriage, if the tops of the shears are worn so the carriage will be worn also.
          #112591
          Anna Jablonska
            @annajablonska79888
            Thanks Graham & Kwil.,
            Saddle and gibs will all be looked at – they don't look bad – but if I'm re-grinding the bed then I will most probably gring & scrape these parts in as well….
            I'll post pics soon….
            Kindest Anna
            #112593
            Paul Barrett
              @paulbarrett57424
              I had the saddle and cross slide reground on my lathe. I was lucky the bed was hardly worn. The shears were ok and very little wear along the 'v's. However the 'v's in the saddle were worn quite a lot and so that was reground as was were the front apron attaches to keep the apron the same height and the leadscrew in line. The cross slide was badly worn on the bottom so that was reground as well as the gib. Brian at Slideway Services did the job for £250 which I thought was brilliant. The lathe is an Ajax badged Universal C8C which is still made to this day. 6 1/2 inch swing x 30 inch between centres. A really well made Bulgarian lathe.
              #112603
              Takeaway
                @takeaway
                Hello – Thirty years ago I aquired an old 3.5" Grayson lathe which was quite worn all round. The lathe was not a great pleasure to use. I was at the time able to take advantage of a a pro toolroom setup. Because the bed was not hardened, I had it skimmed all over on a jig borer. The headstock bearings renewed, a new spindle turned, hardened and ground etc. etc. Result was a smashing piece of kit which I could rely on to do anything I threw at it. So my advice for what it's worth is do it – and if you can manage it for the price of a bottle of scotch – like what I did – then so much the better! ATB – Stuart
                #112669
                Anna Jablonska
                  @annajablonska79888
                  Thanx Paul and Stuart.,
                  Seems that the way to go is forward…..which I will most definitely analyze a bit more before I commit….
                  Don't have Scotch in Poland – obviously Vodka will haveto do – but after the grinding has finished…
                  Anyways – I'll keep you posted on the outcomes…I wish I had a Brian here – but alas I guess I'll just have to find one….
                  Kindest from an even more snowy Poland…..
                  Anna
                  #112673
                  Martin Kyte
                    @martinkyte99762
                    If you intend to keep the lathe get it reground. You are not going to wear it out and have to do it again are you, and this way you get all the benifit rather than waiting for it to get worse.
                    Martin
                    #112682
                    John Stevenson 1
                      @johnstevenson1
                      Anna,
                      Keep your damn snow. wink
                      #112687
                      Wolfie
                        @wolfie
                        I like snow! Good job really considering where I live.
                        #112699
                        Anna Jablonska
                          @annajablonska79888
                          more snow promised tomorrow….smile
                          I'm now off to clear some to the workshop…..
                          kindest Anna
                          Edited By Anna Jablonska on 20/02/2013 21:24:49
