Threads used on electrical brass fittings
Home › Forums › General Questions › Threads used on electrical brass fittings
  • #419797
    Speedy Builder5
      @speedybuilder5
      What threads are used on electrical fittings, between a lightbulb socket and a tubular brass support bracket. I am trying to help out a friend (By telephone) who has a 14mm OD thread which is not metric fine, but still a fine thread which goes into a larger light fitting. I have see somewhere that the thread angle may be 80 degrees.
      Any ideas out there please ?
      BobH
      #26724
      Speedy Builder5
        @speedybuilder5
        #419798
          PG conduit thread maybe
          #419801
          Speedy Builder5
            @speedybuilder5
            thanks Jason, PG are 80 degrees but not a 14mm OD (There is a 14mm cable size though). The 80 degree bit may have been just an idea I had. These fittings are often found on thin brass and steel fittings.
            The light fitting in question was bought in London, wholesaled from USA and made in China ! What hope have I got of telling my friend what thread he has ?????
            #419802
            Robert Atkinson 2
              @robertatkinson2
              No real standard. As Jason says PG is not uncommon, mostly on industrial fixtures though. Brass holders commonly have 10mm x 1.5, 20mmx 1.5 or 1/2" x 26tpi which does not seem to fit your description. Quite possibly some odd pipe thread.
              Robert G8RPI.
              #419803
                Are you sure it is not 1mm pitch, a lot of the smaller size electrical stuff is 1mm pitch eg M10x1
                14mm is also quite close to 9/16 x 26 or 20 tpi
                #419808
                Keith Rogers 2
                  @keithrogers2
                  Back in the day when I repaired chandeliers and light fittings I came across all sorts of threads.
                  Most fitting tended to be Brass thread , 9/16 x 26 BSB is 14.2mm OD so as Jason says is a very likely candidate.
                  Electrical conduit threads are based on american national pipe pitches, so 1/4 NPT would be .540" OD (close to 14mm ) but is 18t.p.i which sounds a bit coarse for the OP.
                  Later fittings were mostly Metric, again as Jason says 1mm pitch being common. Alth'o being from the US I would think that less likely.
                  Keith.
                  p.s. Sorry for the acronyms devil
                  #419809
                  Speedy Builder5
                    @speedybuilder5
                    9/16 x 26 sounds about right, I will give my friend a ring. Anyone live in Lowestoft with a 9/16 x 26 BSB tap ??
                    BobH
                    #419810
                    Sandgrounder
                      @sandgrounder
                      There is a 'British Brass' thread which is exactly 14mm dia, actually 0.5512" and at 26TPI very close to 1MM pitch.
                      from Machinery's Screw Thread Book.
                      Edited By Sandgrounder on 19/07/2019 14:15:34
                      Edited By Sandgrounder on 19/07/2019 14:17:22
