Tangs not on centres
Home › Forums › General Questions › Tangs not on centres
  • #347565
    BOB BLACKSHAW 1
      @bobblackshaw1
      I'm fitting a DRO on my lathe tailstock, with my lathe the all my centers when fitted will foul up when on my clamp DRO fixing when I take them out. All drill chucks and M2, M3 reducers have a tang on the end and are ok when I take them out. My question is why are tangs not fitted to centers, I can understand if no tangs are fitted to drill chucks as it will give around 15mm more on the tailstock, but why not centers.
      Edited By BOB BLACKSHAW on 25/03/2018 17:20:45
      #25904
      BOB BLACKSHAW 1
        @bobblackshaw1
        #347575
        Dave Halford
          @davehalford22513
          The tangs are used to drift out the taper via the slot cut in a drill press. Tailstocks do not have the slot and therefore the tang is deleted
          #347577
          Journeyman
            @journeyman
            If you need a little extra length on the centre to avoid fouling the DRO mounting. Cut some discs same dia as the centre small end from brass or even plastic and stick them on. Will be plenty strong enough to eject the centre.
            not done it yet
              @notdoneityet
              As Journeyman – or drill, thread and insert a suitable bolt/screw/threaded bar to eject them earlier. Hardness might be deciding factor…
              Edited By not done it yet on 25/03/2018 20:09:13
              #347619
              Lambton
                @lambton
                Use a smaller centre in a Morse taper adapter sleeve that has a tang. The adapter & centre are then ejected together. Arc sell a variety at very reasonable prices. (page 6 of the current number 10 catalogue. Usual disclaimer
                Eric.
                #347627
                  You can get screw in tangs.
                  I have a rotating centre that has a screw in button
                  #347630
                  not done it yet
                    @notdoneityet
                    Sure you can (Arc do them), but angs are only really needed where extraction is by wedge? Simple bolts are far cheaper for this problem?
                    Edited By not done it yet on 26/03/2018 11:10:48
                    #347651
                    Jon
                      @jon
                      All aboves a lot of faffing about, just buy what you want with MT tangs job done and self eject.
                      Will also have clearance for the clamp if the ram protrudes 1/4".
                      #347666
                      Martin Dowing
                        @martindowing58466
                        All my MK2 tangs are slotted and threaded M8 to have both worlds.
                        Martin
                        #347682
                          Posted by not done it yet on 26/03/2018 11:09:33:
                          The scew in button gives you the extra retraction but avoids the 'fouling up' the original poster mentioned.
