Suggestions to pack round DC motor so bracket holds
Home Forums Beginners questions Suggestions to pack round DC motor so bracket holds
Viewing 25 posts - 1 through 25 (of 25 total)
  • #439864
    Chris TickTock
      @christicktock
      Hi I have a small 3mm ish gap between my 75 mm Dia DC motor and the 77 Dia mm bracket I have to hold it. There will be some torque but not too heavy duty. Obviously I wish to pack out the motor so when I tighten the metal clamp it holds the motor without turning when used.
      I am thinking of some type of rubber tape or self adhesive tape but thought I would see if any one has any ideas.
      Chris
      #9963
      Chris TickTock
        @christicktock
        #439867
        Emgee
          @emgee
          You could use 3 or 4 (120 or 90 degrees) packing pieces between the 2 diameters, wood should be OK for small motor,
          Emgee
          #439873
          bill ellis
            @billellis45274
            A bit of old rubber matting or cushion flooring would be my choice, I'd steer clear of anything metal. Just ensure any cooling ducts are not blocked.
            #439876
            Mike Poole
              @mikepoole82104
              A piece of inner tube could do the job but they are getting rare with even motorcycles using tubeless tyres, could be worth a cheeky visit to your favourite tyre fitting place.
              #439886
              Nimble
                @nimble
                Hi Chris,
                A possibility would be to use insertion rubber, available in a number of widths and thicknesses and available in nitrile and neoprenr which should prevent stickiness developing if there is any stray oil about.
                Chris TickTock
                  @christicktock
                  Thanks Guys some really good ideas. Not sure what insertion rubber is but will find out.
                  Chris
                  #439890
                  Brian Oldford
                    @brianoldford70365
                    Would it be possible to wind a number of layers of self-amalgamating rubber tape around the motor body making sure you don't obstruct any ventilation holes?
                    Edited By Brian Oldford on 02/12/2019 19:27:40
                    #439895
                    peak4
                      @peak4
                      Go-cart tyres are a useful source of rubber; competition dry track ones being slicks give a nice even surface and the belting internally provides useful reinforcement.
                      Bill
                      Edited By peak4 on 02/12/2019 20:24:05
                      #439903
                      Chris TickTock
                        @christicktock
                        Posted by Brian Oldford on 02/12/2019 19:27:29:
                        Hi Brian, yes it is certainly possible, I have just looked up what amalgamating means which I have understood to mean it bonds to itself to form one. Now that's fine but it would have to grip the body once the clamp was tightened. I suspect it would work. I am minded to use neoprene eithing from a sheet or washers as this material should stay consistent as it is often used for gaskits.
                        Chris
                        #439904
                        Grindstone Cowboy
                          @grindstonecowboy
                          +1 for the wood idea. A very handy source is coffee stirrers from your local coffee shop.
                          #439914
                          Michael Briggs
                            @michaelbriggs82422
                            +1 Emgee, I like simple effective solutions.
                            #439915
                            Chris TickTock
                              @christicktock
                              Posted by Michael Briggs on 02/12/2019 21:27:42:
                              Can anyone advocating the use of wood here give a reason why it might be better than for instance neoprene?
                              chris
                              #439919
                              Paul Kemp
                                @paulkemp46892
                                Posted by Chris TickTock on 02/12/2019 21:35:12:
                                chris
                                Assuming this is for your grinder 'project' it's probably a good idea to have the motor (thus the wheel) mounted rigidly in relation to the rest / what you are trying to grind (or lap).
                                Paul.
                                #439922
                                Chris TickTock
                                  @christicktock
                                  Posted by Paul Kemp on 02/12/2019 21:43:12:
                                  chris
                                  Point taken that a rigid mount is important. However once clamped up neoprene I think would also be firm. There also exists if I use wood an increased risk of causing damage to the motor body as the load will be concentrated on the few points that the wood is positioned.. I agree I am being speculative but will try the neoprene first and the wood as my fall back position.
                                  Thanks for all posts…appreciated
                                  Chris
                                  Paul.
                                  #439924
                                  Ian P
                                    @ianp
                                    chris
                                    Using natural resources is better for the environment.
                                    IanP
                                    #439925
                                    Ian P
                                      @ianp
                                      Posted by Chris TickTock on 02/12/2019 21:49:55:
                                      Chris
                                      If the motor has a cylindrical body and no other mounting features than presumably the manufacturer will have designed the outer casing to withstand being clamped or held so no need to take any special precautions.
                                      Ian P
                                      #439963
                                      not done it yet
                                        @notdoneityet
                                        I think a better solution would be to make a proper bracket/holder to suit the motor and application. Rather than bodging something.
                                        #439967
                                          Posted by not done it yet on 03/12/2019 09:45:30:
                                          dont know What have you got against a simple bushing ?
                                          Engineers have been using them since Noah was a lad.
                                          Ian P
                                            @ianp
                                            I have nothing whatsoever against bushings if they are fit for purpose, although I would not describe go-cart tyres, inner tube rubber, amalgamating tape, Neoprene insertion ('insulation'?) rubber or strips of wood as being simple in the context of a holding the motor and therefore spindle of a grinding tool accurately located.
                                            Maybe I have the wrong end of the stick and the motor being clamped carries a pulley for a belt drive so a resilient mount might be very appropriate.
                                            Ian P
                                            #439973
                                              Posted by Ian P on 03/12/2019 10:20:52:
                                              Ian, [for clarity]
                                              My question was specifically a response to ‘not done it yet’
                                              Mike Poole
                                                @mikepoole82104
                                                The OP suggests resilient mount so I suspect it is not a direct tooling spindle.
                                                #439981
                                                Ian P
                                                  @ianp
                                                  I know (knew) your answer referred to NDIY's comment but TBH his suggestion of a making a proper mount makes perfect sense to me.
                                                  From previous posts of Chriss TT I deduce that he is very particular in doing everything correctly and by the book!
                                                  Ian P
                                                  #439983
                                                  not done it yet
                                                    @notdoneityet
                                                    Posted by Michael Gilligan on 03/12/2019 10:28:35:
                                                    Ian, [for clarity]
                                                    I think Ian responded quite adequately.smiley
                                                    #440034
                                                      Posted by Ian P on 03/12/2019 11:01:57:
                                                      Ian P
                                                      Chris also has a Sherline Lathe and mill, so making a custom mount for a 75mm diameter motor is likely to be quite an onerous task for him.
                                                      He also states that he has a cylindrical motor and a cylindrical clamp [albeit not yet illustrated], which is a little oversize … A situation which is crying-out for a simple split bushing, I would say.
                                                      … and I’m sure that’s in ‘the book’.
                                                      I have no further comment.
                                                      secret MichaelG.
                                                      Edited By Michael Gilligan on 03/12/2019 15:52:20
