Hello everyone,
I own a Stuart 7A steam engine which was not built by me. The engine is not running. Thus I disassembled everything and found out that there is no axial play between the crankshaft and the two bearings.
If I place the two lower parts of the bearings and the crankshaft, the crankshaft is moving freely. If I place the two lower parts of the bearing, the crankshaft and one upper part (doesn’t matter if left or right), the crankshaft is moving freely.
But if the two lower, the two upper parts (without nuts) and the crankshaft is placed, the crankshaft stops moving freely because there is some friction between the crankshaft and the inside of both bearings.
I think there has to be removed some material. Sadly the engine came without the drawings.
Thus I‘m wondering how much play is indicated by the drawings?. What’s the dimension of crankshaft webs, upper bearing width and the needed distance between them to have the necessary play?
Can anyone help me out please?
Thanks in advance
Sebastian
