Stock Supplier Help Please
Home › Forums › Materials › Stock Supplier Help Please
  • #823166
    Tifa 8572
      @tifa857287838
      Hello again
      I’m trying to source a block of steel for a lathe compound modification.
      Basically, I want to swap the slide for a solid block to mount the toolpost to reduce chatter and make parting off a little better.
      Size required is 128mm x 80mm x 52mm (or very near)
      I live in North Shropshire and by the time I factor in postage, costs seem to be well in excess of £120.
      Is this about right?  Or is there a cheaper way of doing this?
      Also, is there a ‘go-to’ supplier that anyone can recommend please?
      Cheers.
      #823170
        Shame you want 52mm as 2″ stock would be less wasteful.
        M-Machine list 2.5″ x 4″ at £8.16 per 25mm so £48.96 for 150mm though they will probably cut you a 130mm length plus about £10 postage
        #823171
        John Haine
          @johnhaine32865
          I did something similar using an iron backplate casting, I think from RDG.  A lot of hacking involved but nice to machine and better for machine parts such as this anyway.  Or CES (If they are still around) may sell you a sawn lump of cast iron.  Depending on your machinery large lumps of mild steel can be a pig.
          #823185
          Andrew Crow
            @andrewcrow91475
            There is also the Brittania tool post from Hemingway at about £48 + postage.
            Although designed for a Myford 7 series it might be about the right size.
            #823189
              Iron rectangle is also available from M-Machine and would be £38.40, just check you can get the exact size needed out of the bar which will have rounded corners but 60 x 130 section should clean up to 52 x 128
              #823202
              Bazyle
                @bazyle
                Find an old cast iron scales weight?
                #823247
                Halton Tank
                  @haltontank
                  You try Rapid Metals for a quote. See cut block
                  Regards Luigi
                  #823271
                  peak4
                    @peak4
                    Personally, I’d wander down to my local scrapyard, but otherwise, I’ve been advised that High Peak Steels are very competitive on price, and by the looks of it will quote you for both steel and continuous cast iron bar.
                    https://highpeaksteels.com/cast-iron-250/
                    Alternatively, for continuous cast bar, try giving these folk a bell
                    https://www.unitedcastbar.com/https://www.unitedcastbar.com/
                    https://www.foundry-casting.co.uk/cast-iron-bar.html
                    See also, in my old home town, particularly if you can drop down to 50mm
                    https://www.ebay.co.uk/str/steelcitygav
                    Bill
                    #823348
                    Tifa 8572
                      @tifa857287838
                      Thank you everyone.
                      Greatly appreciated!
                    Home › Forums › Materials › Topics
