Stainless Steel Pipe
Home › Forums › General Questions › Stainless Steel Pipe
  • This topic has 26 replies, 15 voices, and was last updated 7 May 2015 at 20:31 by Michael Gilligan.
Viewing 2 posts - 26 through 27 (of 27 total)
  • #189015
      Neil the ground anchor would work anywhere except rocky ground, used to use one when I went off roading to fix the winch to when there were not trees etc, if they can take that load then you should be able to buckle the tripod legs before it pulls out.
      Fairly simple design but you may need to find a model engineer to make one on teh cheap for you, telescope would make a handy tommy bar.
      J
      #189025
        Posted by Neil Wyatt on 07/05/2015 18:12:26:
        Interesting idea Clive. would work for a semi-permanent position in the garden. …
        Agreed, a ground anchor and tension wire is an excellent alterntive to gravity, and avoids carrying all those heavy rocks and sandbags around.
        As an engineer … you might find inspiration here … It's a lovely piece of work, and could easily be scaled-up.
