Spindle re-chroming and grinding.
Home › Forums › Manual machine tools › Spindle re-chroming and grinding.
  • #817134
    stew 1
      @stew
      Has anyone had a small lathe spindle hard chromed and re-ground? Who did you use? And what was the cost?
      Many thanks
      Stew.
      #817144
      Howard Lewis
        @howardlewis46836
        Done properly, should be quite effective.
        On buses, we always had worn shackle pins hard chromed and ground back to standard size.
        It was claimed by some that hard chroming actually improved lubrication qualities (coefficient of friction?) of the bearing assembly.
        #817145
        DC31k
          @dc31k
          Old Bike Mart, produced by someone called Mortons Media Group, would have details of rechroming services aimed at telescopic forks (AM Philpot is one such). They would be similar conceptually to a lathe spindle where the outside requires work, and the inside needs some protection from the plating.
          Does the spindle have an internal taper? How will you assure it is concentric with the new outer bearing surface?
          Does it specifically have to be chrome plating? Alternative metals (e.g. nickel) could be more economic as the H&S and environmental issues surrounding chrome make it an expensive process.
          #817148
          David George 1
            @davidgeorge1
            What size spindle and for what machine. I made a new spindle for my M Type Drummond lathe and turned it from EN24T steel and never looked back.
            David
            #817150
            stew 1
              @stew
              It’s for a 1908 Drummond pre-B type.
              I’m going to be making new bearings, (or attempting to do so) so I thought having the spindle re-done would be a good idea.
              It is bored through, so im assuming at the moment that a company that re-works spindles is used to dealing with such things regarding concentricity? I’m not sure though, and it hadn’t occurred to me so thanks for bringing that to mind.
              David, I’m not sure either my C2 mini lathe or Hobbymat MD65 would have the capacity to make a new spindle sadly. The C2 is in bits awaiting better bearings.
              Howard, I’ve not had chance to use that little Adept shaper I got from you by the way…my garage is still in bits! I’m working off one bench in much diminished surroundings, but at least I can do a bit.
              Building work should be starting soon so things are looking up.
              Stew.
              #817151
              old mart
                @oldmart
                Asking any local machine shops would be the best bet, they would know chrome platers and how to prepare the surface for hard chroming. You may not know that chrome and bronze bearings are not recommended, cast iron or white metal will be a better bet.
                #817157
                Andrew Crow
                  @andrewcrow91475
                  If you are going to make new bearings, why not just get your existing spindle re-ground to true it up and then make your bearings to suit.
                  Andy
                  #817162
                  stew 1
                    @stew
                    <p style=”text-align: left;”>Hmm. I guess I just wanted it returned as close to original spec as possible. There’s still a little life in the old bearings and spindle, so I may yet get the machine to make its own spindle once it’s rebuilt. Just exploring options really. I’m always swayed by an easy option, so if someone said ‘oh yeah, just take it to Bert at business X, and it would cost you Y amount of money, I’d probably do that. As long as they were experienced in such work and came with a recommendation from someone who had a similar job done for a similar lathe.</p>
                    Stew.
                    #817401
                    old mart
                      @oldmart
                      Having the existing spindle ground would only result in very little metal removal, only noticable if actually measured. No need for the chrome plating. If you were careful measuring the spindle as is, you could make a drawing for the grinding shop to follow and make some bearings that would be ready to fit in advance. You have to remember that is an old lathe which will never be worth a fortune except to use and enjoy for its original purpose.
