Small Milling Machines
Home › Forums › Beginners questions › Small Milling Machines
  • #11506
    Grant Fisher
      @grantfisher57205
      #650196
      Grant Fisher
        @grantfisher57205
        Looking for a milling machine capable of milling parts for gauge 3 locomotive.
        Preferable small enough to be man handled even if has to be disassembled into more manageable sizes.
        #650204
        Grant Fisher
          @grantfisher57205
          I have a Boxford lathe with 3phase motor. I believe an inverter on some electronic device can be purchased that allows the motor to run on a single phase set up and some devices include a speed control. What makes are available , what is the likely cost of such a device and how easy are they to fit.
          #650220
          David George 1
            @davidgeorge1
            Hi Grant welcome to the forum. There are many small mills about but you should look at ARC https://www.arceurotrade.co.uk/ or have a look at Chester hobby store. https://www.chesterhobbystore.com
            The drive for your boxford lathe I think should be fairly easy, there are many makes and if you look here https://inverterdrive.com/Contact/ you shoukd get an idea of costs involved and that have downloads of how to install a drive and set up for free. There are other supliers around as well which may be cheaper but they can help with most queries on the phone or email.
            David
            #650222
            Thor 🇳🇴
              @thor
              Hi Grant,
              Welcome to the forum. My first milling machine was a Mini-Mill, similar to this. It worked and is still working even after nearly two decades of (ab)use. It is a bit small and I still use it for light work. I mostly use a somewhat larger machine – similar to this. The larger machine can take heavier cuts and is the machine I mostly use for milling. I would recommend a larger milling machine if you have room for it in your workshop.
              Thor
              #650225
              Clive Brown 1
                @clivebrown1
                Hi Grant, I'd add Warco to your list of milling machine suppliers. I have a WM16B, copes very well with my 5" gauge build. For gauge 3 the WM12 or WM14 would be ample and more easily man-handled but the larger size can be occasionally useful.
                Re Boxford, to use the existing motor you need to ensure that it is delta connected, not star, Look on the motor plate. if it is star then it can probably be changed with a biit of know-how.
                For my Boxford, I bought inverter and motor from Inverter Drive Supermarket. Altogether with wiring and control switches the cost was about £250, bit higher now, but you have the motor. A separate control pendant is almost essential IMO..(Tip, choose an inverter with a downloadable "easy start guide" which gives an idiots guide to wiring up the controls.)
                #650226
                Adam Mara
                  @adammara
                  From years of experience buy as big as you can sfford and have space for. I have a Sieg SX2 mill which has given over 10 years of service. I purchased a Sieg sx2.7 from Arc Eurotrade a few years ago, a great machine, but moving it is a 2 man operation.
                  #650228
                  not done it yet
                    @notdoneityet
                    Posted by Grant Fisher on 27/06/2023 21:01:01:
                    New or used?
                    New – as above (Arc preferred)
                    Used – Ebay? Gumtree?
                    I have a Raglan, which suits me. My other (larger) mill is somewhat heavier.
                    #650231
                    not done it yet
                      @notdoneityet
                      Posted by Grant Fisher on 27/06/2023 21:47:00:
                      Look up VFD. Loads on ebay and specialist suppliers. Cost depends a lot on quality – cheap ones may be cheap for good reason (conducted/radiated interference issues, reliability, even safety). Easy to fit if the instructions are followed closely, but depends on the fitter’s ability/skill, of course.
                      #650232
                      Bazyle
                        @bazyle
                        The original Boxford motors are star connected and the star point is buried in the windings and varnished over so you are likely to damage the insulation when digging it out. People and youtube videos will say it was an easy five minute job because they had a newer motor and got lucky.
                        The mill to look for second hand, if not one of the smaller ones mentioned above, is the type called the round column 'mill-drill'.. These were sold in large numbers by many importers eg the Warco 'Minor'. Normally come up at around £500. Some people like to whine about the problems of a round column but it is perfectly adequate for a competent workman.
                        Finally you could just get a 3D printer. An 08 shunter in G3 was shown at the G1 show at Biceter last year on the gaugeone3Dcircle stand.
                        #650269
                        Hollowpoint
                          @hollowpoint
                          Raglan
                          Dore Westbury
                          Tom Senior E type
                          Hobbymat BFE 65
                          #650276
                          Trevor Drabble 1
                            @trevordrabble1
                            Grant , Axminster are presently offering £173 off a small milling machine in their clearance sale.
                            #650287
                            Bob Sillitoe
                              @bobsillitoe83708
                              When I got my Southbend lathe a few years ago I simply replaced the 3ph motor with a single phase one, which works fine. However I have recently refurbished a milling machine, with this I have put on a 3phase motor with variable Frequency Drive – it works great and if I was doing the lathe now I would do the same as the variable speed would be useful at times.
                              Bob
