silver solder disaster part 2
Home › Forums › Beginners questions › silver solder disaster part 2
  • #111458
    Bill Dawes
      @billdawes
      Hi all. a while ago I posted my traumas with my GLR vertical boiler silver soldering.
      Well after a few nervous reheatings my intitial leak test is good.
      This was at just a few psi of air not the full blown hydraulic pressure test.
      Ironically the only leak I had was back out of the check valve which I had fitted with an adaptor to take a tyre connector. Tried cleaning the ball and blowing out but air still bubbling out.
      Now my question to you experts is this.
      Is the valve faulty / will it 'bed in' / does it need some work on it to bed it in/ or is this to be expected on air as presumably it is designed to retain hydraulic pressure.
      Bill D.
      #6571
      Bill Dawes
        @billdawes
        #111465
        Russell Eberhardt
          @russelleberhardt48058
          It will probably be fine on hydraulic test. Do you have a suitable test rig?
          Russell.
          #111466
          Nigel Bennett
            @nigelbennett69913
            Bill
            Air is a much more searching medium than water, so will find gaps that water won't. However, for an initial hydraulic test, it can be conducted on a bare boiler – with the holes plugged with solid threaded plugs. On hydraulic test your leaking valve won't be a problem! The extra pressure on hydraulic test will also assist in sealing any leaks from the check valve.
            If it's a ball valve, try fitting a nitrile rubber ball. You could also burnish the seat to improve the seating of the existing ball or whatever.
            #111550
            nigel jones 5
              @nigeljones5
              hi – my clacks often leak on air but seldom do on water/steam. If there is any crud on the ball seat air isnt good at self cleaning but steam will soon get rid of it.
              #111807
              Bill Dawes
                @billdawes
                Successful hydaulic test, check valve was fine, steam trial next. Thanks for you help on this and my previous woes.
                Silver soldering a boiler is certainly a job to try and get right first time!
                Bill D
