Scotch Pads
Scotch Pads
Home › Forums › General Questions › Scotch Pads
  • #193256
    Vic
      @vic
      I often use the green Scotch Pads (scourers) sold in supermarkets as a general purpose abrasive for some jobs. Does anyone know what the grade is likely to be for these? Ive also bought some of the finer Grey ones in the past and am pretty sure it had some sort of grade on it but I no longer have the packet.
      #23932
      Vic
        @vic
        #193259
        mechman48
          @mechman48
          I bought some of the grey pads from B & Q a while back; they are graded as 'Fine & superfine'. I would compare them to wet & dry 800 -1000 grade respectively.
          George
          #193268
          MICHEL GIRARD
            @michelgirard65811
            I think this link should answer your question:
            http://www.evergreen.edu/biophysics/technotes/fabric/finish.pdf
            Michel
            #193345
            capnahab
              @capnahab
              More info here
              No affiliation etc..
              #193352
              Vic
                @vic
                Thanks folks.
                #193356
                Gordon W
                  @gordonw
                  We use these pads, mostly for there intended use, but do have one or two in the w/shop. I find that the quality varies and some start falling apart after a short time. Maybe they are from different sources but it is worth checking before using on a significant job.
                  #193363
                  Ian S C
                    @iansc
                    I got some at the $2 shop some years back and found they had virtually no abrasive properties at all. I found a use for them as air filters on the intake of my compressor, and the Kawasaki engine on my home built generator.
                    Ian S C
                    #193369
                    Vic
                      @vic
                      The blue ones are non abrasive, as I believe some of the white ones are as well.
                      #193502
                      Ian S C
                        @iansc
                        The ones I got are grey, and come from some where in the east, they are not Scotch Brite.
                        Ian S C
                        #193510
                        Tim Chambers
                          @timchambers76147
                          Posted by Ian S C on 15/06/2015 13:45:58:
                          Ian S C
                          There's your answer!
                          I remember when I worked in a dairy and they tried to fob us off with a cheap substitute for Scotchbrite for cleaning up the cheese vats.
