S7 Tail stock
S7 Tail stock
Home › Forums › Workshop Tools and Tooling › S7 Tail stock
  • #456439
    Alan Gordon 4
      @alangordon4
      My tail stock on my S7 is slightly low, Has anyone any advice on how to adjust the height ?
      #19652
      Alan Gordon 4
        @alangordon4
        #456443
        peak4
          @peak4
          Is it actually low, or pointing downwards due to wear?
          A possible suggestion if it's horizontal, but low, would be to split top from base and insert lengths of feeler gauge/shimstock. Starrett do long lengths of feeler gauge, available off ebay at a reasonable price.
          If pointing downwards, then scrape or re-machine and then make up the lost height as above.
          Bill
          #456444
          Martin of Wick
            @martinofwick
            Is it causing a problem ie. when drilling for instance?
            By how much is it offset?
            Did you determine this error by using two newly cut centres (made on the lathe in question)?
            If not, how confident in your centres are you? if you rotate the centres does the error vary?
            Did you lock up the tailstock and barrel when measuring?
            Did you check if the error varied at differing tailstock extensions?
            Did you take the unit of and check for bits of swarf, burr etc on the sole of the tailstock?
            answers to these points may help identify the cause of the error.
            Edited By Martin of Wick on 10/03/2020 12:02:37
            Edited By Martin of Wick on 10/03/2020 12:03:58
            Edited By Martin of Wick on 10/03/2020 12:07:22
            #456446
            Alan Gordon 4
              @alangordon4
              Thanks guys for the help and information, I will certainly check out everything mentioned
              #456455
              old mart
                @oldmart
                Having a test bar such as this one comes in very useful and its not too expensive. It can be held between centres also.
                Harry Wilkes
                  @harrywilkes58467
                  Would not bother with Old mart's kink i ordered from the same company delivery March 2nd no show no reply to messages have now asked for refund 'what this space'
                  I do realise that due to the current problems people maybe facing with deliveries due to the coronavirus that dos;nt stop them replying to messages
                  H
                  #456459
                  old mart
                    @oldmart
                    I have two test bars, both Indian origin, a 7" and an 11", MT2. I bought them some years ago, so have no up to date info on their availability at present. Checking the sellers feedback before buying on ebay is always recommended.
                    #456461
                    old Al
                      @oldal
                      join a model engineers club, bound to be a test bar or two there
                      #456559
                      David George 1
                        @davidgeorge1
                        Don't forget to inspect the Morse taper inside the tailstock I have seen damage where drills have spun under load and where swarf gas been pressed in and stuck and damaged. Use a blued standard test bar if available or an undamaged drill/ream shank and micromiter blue.
                        David
                        #456820
                        Harry Wilkes
                          @harrywilkes58467
                          Posted by Harry Wilkes on 10/03/2020 14:47:07:
                          H
                          Update I have today received my item seller said deley down to holiday season and coronavirus, which mybe correct but why did'nt he answer my messages until I made ebay complaint !
                          H
