Removing Flux
Removing Flux
Home › Forums › General Questions › Removing Flux
  • This topic has 11 replies, 9 voices, and was last updated 2 May 2019 at 15:27 by Former Member.
  • #407459
    Paul Lousick
      @paullousick59116
      What is good for removing flux on copper, bronze or brass after silver soldering ?
      Paul
      #26588
      Paul Lousick
        @paullousick59116
        #407462
        Thor 🇳🇴
          @thor
          Hi Paul,
          Diluted sulphuric acid is often used for pickling, but must be handled carefully. I now use citric acid in warm water.
          Thor
          #407463
          mechman48
            @mechman48
            I have used citric acid, from the home brew counter in a well known discount store, vinegar also works well.
            George.
            #407464
            Former Member
              @formermember19781
              #407465
              Simon Collier
                @simoncollier74340
                Is this a trick question Paul? The obvious answer is sulphuric acid. A friend recently found 1 litre bottles of concentrated H2SO4 in a cleaning supply shop. Cheap too. The plastic bottles are weirdly heavy too, reflecting the concentration of relatively heavy sulphate ions. I use it at 2 molar (roughly 1:10) but that is overkill.
                #407473
                Paul Lousick
                  @paullousick59116
                  No trick Simon. I have done a lot of welding and brazing but have not pickled the metal to clean. (My search of previous posts did not come up with anything). Will give the citric acid a go first to see if it works.
                  I have used typist's correcting fluid to mask the metal where I did not want the solder to flow. This worked but is there a better method ?
                  Cheers, Paul.
                  Edited By Paul Lousick on 02/05/2019 12:13:13
                  #407474
                  Simon Williams 3
                    @simonwilliams3
                    Hi Paul, this comes up every so often, and the perceived wisdom seems to be brick cleaner from your local builders merchant. I've tried it and it works a treat. Buy the one that actually says it contains citric acid, other formulations exist.
                    Good luck Simon
                    #407475
                    Nick Clarke 3
                      @nickclarke3
                      Most acid based brick cleaners appear to be based upon 10%-18% Hydrochloric Acid (sometimes otherwise described as Hydrogen Chloride)
                      Citric Acid is often cheaper when bought from a shop selling homebrew ingredients.
                      #407493
                      BW
                        @bw
                        Baking section at Tescos, Sainsburys, Woolworths, Foodland, Safeway etc etc will usually have citric acid in powder form. Quite cheap.
                        #407494
                        Samsaranda
                          @samsaranda
                          Cheaper source of Citric Acid is the internet, food grade available at very reasonable cost, much less than supermarket prices. Citric Acid works well for me and I wouldn’t contemplate using Sulphuric or Hydrochloric, way too dangerous, Citric takes longer to achieve the same results but we are not working in industry tied to production schedules so a bit extra time doesn’t matter.
                          Dave W
                          #407499
                          Former Member
                            @formermember19781
