Reamers – hand vs MT
Home › Forums › Beginners questions › Reamers – hand vs MT
  • #80391
    Wolfie
      @wolfie
      I have a couple of hand reamers, but when I visited a colleagues workshop I noticed all his were morse taper reamers to fit in his lathe.
      I need to get a couple more and I’d like to stick to one type.
      Any difference or is it a case of choice?
      #5809
      Wolfie
        @wolfie
        #80400
        Sub Mandrel
          @submandrel
          Hand reamers have a taper over the first inch or so, while machine reamers are effectively parallel and cut on the end. Most of mine are hand reamers, I only have one machine reamer.
          Tony Martyr
            @tonymartyr14488
            I have just posted a photograph of using a machine reamer to finally align the 6 main bearings of a triple expansion engine. I find MT reamers both easier to use in the lathe of milling machine than hand reaming.
            #80409
            David Littlewood
              @davidlittlewood51847
              Machine reamers are the only ones which can ream a blind hole to size all the way down. Conversely, they cannot be used by hand as there is no lead; only hand reamers are suitable for this job.
              David
              #80421
              Wolfie
                @wolfie
                Now I’m more confused, what are ‘machine’ and ‘chucking’ reamers??
                #80422
                Brian Dickinson 2
                  @briandickinson2
                  Have a look here
                  http://www.taylorandjones.co.uk/ this may clear things up for you.
                  Happy christmas
                  #80424
                  Nicholas Farr
                    @nicholasfarr14254
                    Hi Wolfie, Machine reamers have a Morse taper for fitting into you tail stock, and I think chucking reamers have a parallel shank without a square at the top, to fit into a collet chuck.
                    Regards Nick.
                    seasons greatings to all.
                    #80426
                    David Littlewood
                      Sorry Wolfie, they are, AFAIK, different names for the same thing: a reamer with no gradual taper at the business end, instead they have a 45 degree bevel which does all the work, the rest of the flutes are all to nominal diameter (usually + a tenth or two). They also usually come either with a morse taper shank, or with a plain shank with no flats for a tapholder. Hand reamers have a very, very gradual taper of about 2 diameters length, and the diameter at the front end is a few thou less than nominal. You may have to observe the width of the lands to see the extent of the taper more clearly. The cutting action is spread over all of the taper, but its purpose is to allow you to get the reamer into a hole while holding it in a hand tapholder – for which purpose they normally have square flats at the end of the shank.
                      You can use hand reamers in a machine, but you can’t (sensibly) use a machine reamer by hand. OTOH, as I said above, a hand reamer cannot ream a blind hole to the bottom.
                      Crossed with the other two posts; I don’t believe there is a difference between “machine” and “chucking”, other than what various makers choose to call them.
                      David
                      Edited By David Littlewood on 24/12/2011 17:28:14
                      #80439
                      Steve Withnell
                        @stevewithnell34426
                        Chucking – goes in the chuck, Machine – goes in the machine tailstock taper? But both are parallel reamers as per note above.
                        Steve
                        #80444
                        Terryd
                          @terryd72465
                          Posted by Wolfie on 24/12/2011 13:36:38:
                          Hi Wolfie,
                          Forget reamers, make your own D bits (see GH Thomas’ books) . Every bit as good as reamers for most model engineers purposes.
                          Happy Yuletide,
                          Terry
                          #80458
                          David Littlewood
                            “Chucking – goes in the chuck, Machine – goes in the machine tailstock taper? But both are parallel reamers as per note above.”
                            No; like I said, it’s entirely up to the manufacturer, for example this one.
                            David
                            #80606
                            Sub Mandrel
                              @submandrel
                              Terry’s right, d-bits do as good a job as a reamer if well made and sharp.
                              But they can need a little help to make sure they start accurately (e.g. drill a lead-in at full diameter) unlike a reamer.
                              You can vary the end of a d-but to create flat, tapered (either way) or round bottomed holes.
                              The d-bit acts as a single point cutter, and if held rigidly enough can even be used as an endmill or slot drill or a flycutter. This means it can, used carefully, be used to drill a hole without a pilot (although this does mean along cutting edge. the main limit is the risk of overheating a carbon steel d-bit and blunting it rapidly.
                              Its also possible to make them from HSS blanks or even to use a boring bit as a D-bit if it is the correct size.
                              As the shoppping channel might say “Is there anything D-Bit can’t do…?”
                              Ian S C
                                @iansc
                                A similar tool to the D bit is the tool makers reamer. In stead of being made like the D bit, the front end is cut at an angle of about 20*, and if its for one or two holes in brass or aluminium hardening is not usually required. I use that system on my hot air engines, drill under size, then make up a reamer from the shaft that will eventually go in the hole. An ordenary fluted reamer can leave corrigations lengthwise up the bore, not usually a problem, a spiral reamer helps to eliminate the chattering. Ian S C
                                #80662
                                Ian S C
                                  @iansc
                                  Click on photos for a rough sketch. Ian S C
                                  #80666
                                  Wolfie
                                    @wolfie
                                    Whats a D bit?
                                    #80699
                                    colin hawes
                                      @colinhawes85982
                                      Reamers are intended to produce a very close tolerance hole and are most likely to do this if allowed to float a little, to follow the drilled hole, by holding them the minimal amount in the drill chuck.Reamers with a taper shank are more likely to have a tendency to bore the hole due to inaccuracy in a tailstock.
                                      Colin
                                      #80707
                                      Sub Mandrel
                                        @submandrel
                                        A d-bit is typically made from silver steel. the basic form is ground or machined away to a half-circle or D-shape in cross section. As George Thomas makes very clear you should leave it slightly THICKER than half the diameter as this stops it cutting on the edges and you get a true- to-size hole.
                                        The end needs to be relieved at about 7-10 degrees to create a cutting edge, and you should also grind awa the non-cutting half of the end at a similar angle for clearance. You’ll have to get a mental picture of the cutting action to make sure you grind away the correct side.
                                        Some people angle right across, to create an angled point at the cutting corner, others make it straight across to get flat bottomed holes.
