Raising the L5
Raising the L5
Home Forums Beginners questions Raising the L5
  • #185760
    nigel jones 5
      @nigeljones5
      No..its not sunk…. Now that ive got it 3 inches off the floor I can get a spanner under it. I want to raise it 6". It has 6 bolt down lugs on the base, would it be safe to use these lugs to raise it off the floor. Idea is to put a piece of thick threaded bar through each lug with a nut between floor and lug and raise by holding bar and turning nut. This will allow accurate levelling. Given that it weighs the same as a small elephant I dont know if lugs intended to hold it down will also be strong enough to raise it up. Instructions tell you to bolt it to the floor then fill the base section with concrete!
      #7555
      nigel jones 5
        @nigeljones5
        #185764
        Ian S C
          @iansc
          Hi fizzy, I'd tend to raise the lathe the required amount by pouring a concrete slab with either the bolts set in the concrete, or anchor bolts of some kind into holes drilled in the concrete. You could instead use wooden sleepers with bolts that go right through and into the floor.
          Ian S C ! wot appened!
          #185768
          Nicholas Farr
            @nicholasfarr14254
            Hi fizzy, I would agree with Ian's ideas. If you just use threaded rod there is the danger that they may buckle sideways when you get the lathe running, which may well break one or more off and even tip the whole thing on to yourself.
            Regards Nick.
            #185770
            Jesse Hancock 1
              @jessehancock1
              Hi Fizzy, If you can get hold of some heavy angle lipped under the full length of the lathe(?), drill holes to match the lugs and resort to your original idea I reckon you should be okay. (A bit of belt and braces)
              #185775
              Bazyle
                @bazyle
                If the lathe were sitting on 6 in 'stilts' any rocking would put a bending moment on the lugs which they won't like. A few engineering, not lightweight, bricks isn't going to break the bank.
                #185779
                Involute Curve
                  @involutecurve
                  Mine is sat on engineering bricks its been that way for about 10 years inc a house move, all I did was lift it and sit it on the bricks that are bedded in to floor tile adhesive, never had a problem.
                  shaun
                  #185803
                  S.D.L.
                    @s-d-l
                    Get some universal channel 100 or 150 high as required weld up a frame, gusset top to bottom either side of fixings.
                    Bolt lathe to frame, lift and put machine mounts frame to floor for level ling.
                    frame probably ends up as two rectangles first one under head stock the 3 prices to side under tail stock
                    Steve
                    #185833
                    Ian S C
                      @iansc
                      If you go the way of jacking it up on threaded rods, once its up box in around the rods, and pour in some ready mix concrete, not knowing the volume I would guess you might need 3 bags.
                      Ian S C
