Polymorph Half-nut
Polymorph Half-nut
Home › Forums › Workshop Tools and Tooling › Polymorph Half-nut
Viewing 25 posts - 1 through 25 (of 26 total)
  • #195402
    James A
      @jamesalford67616
      I have almost finished settingup my Flexispeed lathe thatI received at Christmas, just needing to buy some polyeurethane belting and wire in the motor.
      One modification that I would like to make in time is adding a half-nut so that I can disengage the leadscrew. Rather than trying to find a suitable left-handed tap, I am thinking about using polymorph to form the nuts instead. Does anyonehave any experience of using it for anything similar and, if so, how well did it last?
      James.
      #17760
      James A
        @jamesalford67616
        #195404
        Les Jones 1
          @lesjones1
          Hi James,
          I think acetal would be more suitable than polymorph. Have a look at this information on making half nuts from acetal.
          Les.
          #195455
          James A
            @jamesalford67616
            Les,
            Thank you for the link, which looks useful. I have a length of suitable material, so shall have a look at this method.
            James.
            #195465
            Douglas Johnston
              @douglasjohnston98463
              I bought some polymorph a few years ago, but have not done much with it apart from playing with it. It might be worth a try for this application and I might give it a try myself. I don't know much about the properties of polymorph but the moulded objects are quite tough and not unlike acetal/delrin and would be easier to mould round a leadscrew since the temperatures involved are much lower.
              If you have some polymorph, give it a go James and report back. When I get an odd moment I will try it myself on something smaller to see if it is a runner.
              Doug
              #195540
              James A
                @jamesalford67616
                Doug,
                I shall be interested to hear how you get on, should you give it a try. I shall have a go myself with the polymorph and, if it is unsuccessful, try using delrin instead.
                James.
                #195562
                DMB
                  @dmb
                  I have seen detailed instructions of how to make a new L/S nut with, I think, Delrin. I think it was on HMEM.
                  #195627
                  DMB
                    @dmb
                    Hi James,
                    Further to my prev. post, I have just been into homeshopmachinist.net and typed "leadscrew nut" in the search box @ the top and immediately comes up with what I was remembering earlier – round black Acetal bar. They say bore a blank to thread OD less ONE thread depth, saw in 1/2 axially. Polish and oil L/S and clamp 2 halves of L/S blank on to L/S and grip the lot in bench vice.Use a hot air gun, NOT gas torch! to warm up L/S, and as heat travels along L/S, it will soften the Acetal so tighten vice jaws. Keep this up til 2 halves of nut close up.They reckon it takes 10-15 mins.There are further instructions for removing the nut and finishing it but you will have to look it up. I dont want to repeat the lot – someone may object. I note nothing said about OD of nut so I will guess it could need a wall thickness of thread depth X 2 + OD of L/S. If you try this, perhaps you could post description of how it went for benefit of anyone else needing to do similar. Good luck.
                    John.
                    Edited By DMB on 02/07/2015 21:37:57
                    #195632
                    Les Jones 1
                      @lesjones1
                      Hi John (DMB),
                      That sounds like the link I gave in my post at 08:31 on 30/06/15
                      Les.
                      #195670
                      DMB
                        @dmb
                        Hi Les,
                        U R dead right – I forgot 2 check 4 that.
                        John.
                        #195798
                        James A
                          @jamesalford67616
                          Thank you all for the contributions. I shall have a go with the polymorph to see how well it works and post my experience for others to see. IF it fails to do the trick, I shall try the Acetal option.
                          JAmes.
                          #195800
                          Ady1
                            @ady1
                            Various plastics can be used but they tend not to last long, especially if you are a regular user
                            If you want an easy to machine material and decent longevity use aluminium
                            #195801
                            James A
                              @jamesalford67616
                              Posted by Ady1 on 05/07/2015 11:03:17:
                              True, except that my reason for wishing to use ploymorph or, perhaps, Acetal, is a lack of a suitable left-hand thread tap to make a metal half nut. To be honest, I have no idea what thread it is either. I suppose I could experiment with casting one in alumimium, but Ireally would rather avoid this route.
                              Regards.
                              James.
                              #195874
                              Roderick Jenkins
                                @roderickjenkins93242
                                James,
                                If your Flexispeed is like mine then the leadscrew is 12tpi square form. I have no direct experience of this but my understanding is that square threads will not disengage from half nuts, they have to be ACME form. I hope others can confirm or deny this.
                                Rod
                                #195875
                                  Posted by Roderick Jenkins on 05/07/2015 21:35:37:
                                  … my understanding is that square threads will not disengage from half nuts, they have to be ACME form.
                                  That's my understanding too, Rod
                                  ACME, or similar [Trapezoidal, etc.]
                                  James A
                                    @jamesalford67616
                                    I have now had a go at using polymorph to make a nut for the leadscrew, albeit not half nuts.
                                    The leadscrew nut on my Flexispeed is a small, rather narrow, casting with the thread cut into it. Over time, this has worn and there is a lot of backlash in the nut. To try and remove this slack, I moulded some polymorph around the leadscrew and, once set, sawed and filed it square. I then screwed this plastic nut to the exisitng metal nut to bolster it. It has worked well and removed all of the slack whilstremaining loose enough to operate.
                                    However, the impression that the material gives is that whilst it will last for a while, it is unlikely to cope with a large amount of use. Mind you, it was so quick to make the nut that even it has to be replaced each year, it is no hardship.
                                    James.
                                    #207745
                                    Martin W
                                      @martinw
                                      James
                                      Would there be any mileage in mixing in something like brass or bronze powder into the polymorph as a filler to increase its life and improve the bearing surfaces. There are lots of metal powders available here that might be suitable.
                                      Cheers
                                      Martin
                                      #207751
                                      James A
                                        @jamesalford67616
                                        Martin,
                                        To be honest, I had never even considered that, which seems like a good idea to me, especially as I imagine that it will make to polymorph easier to file and shape. When this version of the nut expires, or if I use the polymorph for anything else that is similar, I shall try adding some powders.
                                        James.
                                        #207757
                                        John Haine
                                          @johnhaine32865
                                          Look up Moglice.
                                          #207762
                                          Martin W
                                            @martinw
                                            Had a look at the Moglice site and it looks very interesting. At samples coming in at 10 euros for 50 grm (Ex VAT & Postage) it is cheap enough to have a play with. It was interesting to see that in their application sheets they were using it to repair/remake threads on lead screws etc. As they say, just ensure that the cast is on the least worn part of the thread or else the new nut nut will not run over all the thread.
                                            Cheers
                                            Martin
                                            PS It sound like something a cat might catch !
                                            #207763
                                            Ian S C
                                              @iansc
                                              A number of the plastics are available with various fillers such as bronze, graphite, and oil.
                                              Ian S C
                                              #207768
                                              Douglas Johnston
                                                Well done James, I'm afraid I never did get round to trying it myself, but I will move it further up my 'to do ' list. As a matter of interest did you use hot water to soften the polymorph or use a different technique?
                                                Doug
                                                #207907
                                                James A
                                                  @jamesalford67616
                                                  Posted by Douglas Johnston on 14/10/2015 10:32:40:
                                                  Doug
                                                  Doug,
                                                  I used boiling water. I had a mixture of fresh polymorph granules and a roughly moulded lump that was left over from making a plastic hammer head. The fresh granules melted perfectly well, but the formed lump proved much harder to soften.
                                                  JAmes.
                                                  #207931
                                                  Douglas Johnston
                                                    Thanks James, I must dig out my polymorph and have a go.
                                                    Doug
                                                    #208075
                                                    mark smith 20
                                                      @marksmith20
                                                      Ive used polymorph on occasional for work holding jigs, One thing i found is that it does tend to take a lot of heating for previously used lumps to be of use.It also doesnt tend to hold its shape very well . I think its a case of differential cooling but it is rather annoying ,when a curved jig straightens out a lot when cooling.. It may be more suited to small items .
