Organising M.E. index spreadsheet
Home › Forums › Model Engineer. › Organising M.E. index spreadsheet
  • #551953
    steamdave
      @steamdave
      Is it possible to organise Excel into ascending or descending order across all columns?
      I particularly would like to reorganise the Model Engineer index Excel spreadsheet to show contributors in alphabetical order with their contributions. This would make it easier to search for particular articles.
      I can sort and filter Authors in alphabetical order but the remaining columns are not sorted using the Sort & Filter button.
      The Emerald Isle
      #37870
      steamdave
        @steamdave
        #551958
        DC31k
          @dc31k
          #551959
          Bizibilder
            @bizibilder
            Highlight the entire sheet and then use custom sort to sort on the column you require – the whole sheet will be sorted.
            #551963
            Calum
              @calumgalleitch87969
              Dave, if you highlight the entire table before turning on the sort/filter tool (or off and on again), it should keep all the rows in order. Let me know if you're struggling and I'll see if I can sort it out for you.
              #551966
              Paul Lousick
                @paullousick59116
                Make a copy and use it for sorting columns. Unlike a database (MS Access, etc) the data in the columns for each record is not linked together and easy to mix them up and ruin the file.
                Edited By Paul Lousick on 30/06/2021 13:13:18
                #551992
                steamdave
                  @steamdave
                  Thanks gents for your help. All sorted now.
                  The Emerald Isle
                  #551995
                  John Haine
                    @johnhaine32865
                    You have probably seen this now, but if, having sorted, you click on the little down arrow next to the column head it gives you a list of all the contents in that column with a tick box. If you untick them all by clicking on the "select all" box then click the (say author) you want it will show you just the relevant entries.
                  Home › Forums › Model Engineer. › Topics
