oil leaking from apron
Home › Forums › Beginners questions › oil leaking from apron
  • #6594
    Trevor Jenkins
      @trevorjenkins62731
      1232 lathe
      #113053
      Trevor Jenkins
        @trevorjenkins62731
        Hello I have a 1232 lathe from warco, just about 1 year old, 8 months ago I noticed an oil leak on the bottem of the apron, would anyone know how to fix this probleme, not to sure exactly where the oil is leaking from.
        regards Trevor Jenkins.
        #113120
        Gray62
          @gray62
          Check the oil drain plug on the bottom of the apron, also the seal around the oil level sight glass.
          Also if it's anything like my GH1330 from the same stable, any parts that are attached to the apron have their bolt holes drilled right through the casting, so check that all mounting bolts are tight.
          Graeme
          #113121
            My 280 leaks from the apron and gearbox, the swarf soaks up what comes out the apron and what comes out the gearbox drips into the cupboard and keeps the rust away from the chucks etc stored in there. Just top it up regularly.
            J
