New Vice
New Vice
Home › Forums › General Questions › New Vice
  • #113421
    Boiler Bri
      @boilerbri
      I need to replace my 'chinease made' vice with a new one, has anyone bought one of these? If you have are they any good?
      Vice on Ebay
      Bri
      Edited By David Clark 1 on 01/03/2013 18:19:58
      #22495
      Boiler Bri
        @boilerbri
        #113424
        David Clark 13
          @davidclark13
          Hi Brian
          I would want to know what the inside of the vice between the jaws is.
          Some of these cheap vices have a rough casting between the jaws or a bit of a rough gap so you can't put a parallel in it.
          Also, the base loses you headroom but if you remove it, you can only use the vice at 90 degrees to the X axis.
          That would be fine for most of the time but 10% of the time you may need the vice in line with the X axis and unless your Tee slots are the right distance apart you may not be able to clamp it down.
          regards David
          #113426
          John C
            @johnc47954
            Bri, whereabouts are you? RDG are advertised as being at the Manchester Modelling Exhibition in the Trafford Centre tomorrow – you could go and have a look.
            magpie
              @magpie
              If the RDG stand at the Manchester show is the same as last year, it will not be very big and only have a small amount of there stuff on it.
              Cheers Derek.
              #113447
              Chris Trice
                @christrice43267
                I’ve got one of the vices in the link and it’s very good (although prone to rusting), however I don’t use it on my milling machine as I prefer a similar one but without the swivelling base.
                #113450
                Boiler Bri
                  @boilerbri
                  Thanks for the ad-vice. I am ok with height as i have a warco that the head can go up and down. It was the quality side of things that worried me. On the one that i have the moving part lifts a little when i clamp things in it. If i forget to tap the part level i end up with a taper cut.
                  No chance of Manchester, her who must be obeyed needs to visit a shop in colne tomorrow and the nearest i will get to anything like moddeling will be Howarth railway.
                  Cheers
                  Bri
                  #113451
                  magpie
                    @magpie
                    Brian, the show is open on Sunday as well.
                    Cheers Derek.
