New Member intro – with a bowed ME beam aluminum bedplate question
Home Forums Introduce Yourself – New members start here! New Member intro – with a bowed ME beam aluminum bedplate question
Viewing 25 posts - 1 through 25 (of 26 total)
  • #342529
    Les Wilder
      @leswilder20052
      Hello all! I’m a mechanical engineer in the US, and new to this forum.
      As an introduction, about 45 years ago, I became interested in model steam engines and discovered and subscribed to Model Engineer for a few years. However with a family to support, and a house to take care of, there was no time for this hobby.
      The solution? Purchase the Stuart No. 9 castings from Stuart, and the ME Beam castings from Reeves. And promise my wife that I would not start on them until retirement. Retirement has now arrived!
      Many years ago I acquired a circa 1942 7-inch Rivett “speed” lathe – (no power feeds) but very solid and precise – and happily used it off and on for miscellaneous tasks. Also acquired a small Clausing milling machine. So I felt ready for a real project! I dug out the kits and looked them over.
      In examining the kits, I saw that the Stuart has a 7-inch flywheel, and the beam engine a 91/4-inch flywheel. Advice on the web pointed to the beam engine as a better first model. So decided to start with it and worry about finding a way to handle the too-large flywheel later.
      I then noticed that its cast aluminum (or aluminum alloy) bedplate is bowed upward about 1/8-inch along its length, like an inverted rocker of a rocking chair, with a slightly sharper bend upward near one end. Because the bottom flange is only about 1/8, machining it flat is not feasible.
      Searching the web for ways to bend cast aluminum led to many contradictory opinions. Anneal to 400 degrees Fahrenheit, then bend while hot. Don’t bend while hot. Don’t heat at all. Use a hammer to rapidly reshape. Bend slowly. And: Don’t even try – it will crack.
      So I emailed Reeves about this 45 year-old defective part. In response I was sent a current price list with the info that they were not the same company as the previous AJ Reeves. A new bedplate would cost close to or more than what I paid for the entire set of castings. And the 90 tooth gear which also had never shipped was much more expensive.
      Similarly for the drawings, which never came with the kit. I asked about bending the casting, with the response that they had no technical department that could help.
      So – should I try to flatten it? If so, how to approach the task. Should I purchase a new one, hoping it would arrive flat? Brunell offers castings, drawings and construction notes – are they all interchangeable with Reeves items? Do both companies provide the same drawings, or do I need the Reeves drawings to match their castings. Do they use different foundries? Is their quality and service comparable?
      Should I assume a new bedplate might also be distorted, and I’d be better off fabricating one from one or two pieces of flat stock aluminum?
      Not sure where to post this, but as a newbie, perhaps I can be excused as this also serves as an intro.
      Les
      #40279
      Les Wilder
        @leswilder20052
        #342548
        Ian S C
          @iansc
          Welcome to the forum Les, I'm not too sure on straightening your casting, someone will have an idea on that.
          Don't a afraid to post pictures, they help people decide on what path to take in a remedy for something like this.
          Ian S C
          #342551
          John Haine
            @johnhaine32865
            I think you might as well try straightening it – not sure how though! – with a view that if that fails you can always make a new one from flat stock. There's a member here – JasonB I think? – who makes a lot of very impressive models from stock materials.
            #342571
              You have nothing to loose by trying to straighten it, I would probably pack up under the low points and apply pressure to the high area in the middle.
              If that fails then think about making a base from scratch, just needs a plate with the holes milled into it and a moulding around the edge, strip of 1/8" flat bar screwed to the underside to give the bottom flange, JB Weld on the lugs for the hold down bolts around the edge and add thinner pieces of plate to form the raised areas that the parts sit on though this last item could be left off.
              As for the other question about the two suppliers I will just say stay with Reeves 100%.
              Gear does not really transmit any power so could be cut yourself and tracking down the old issues of model engineer will provide you with both the drawings and build description.
              These are a couple of home made bed "castings" all from plate and strip.
              #342574
              Involute Curve
                @involutecurve
                I straighten cast ali quite often, levers foot rest etc on motorcycles, when I or my lads fall off during trials MX racing or what ever, I use heat, I heat the metal with a flame until it just chars wood when rubbed on the surface, bend immediately whilst hot, I've heard of smearing on washing liquid again heat until it turns black, or do it with temp sticks available from welding supplies.
                Shaun
                #342581
                  A Jason says, you won't lose anything by trying to straighten it.
                  To anneal 'normal' aluminium alloys successfully, make some streaks on it with ordinary bathroom soap. Heat from the other side so you don't directly scorch the soap. When it turns dark brown, remove the heat.
                  It will probably 'age harden' so you need to straighten it the same day, within an hour or two if possible, while it is at its most malleable.
                  Hopper
                    @hopper
                    +1 on warm it up and bend it out straight. I would put it under my press, with gentle pressure, or in large vice under tension and then heat as said until soap browns up. You will almost certainly need to pack it up so you bend about 5 per cent further than the desired finished result as there is usually some spring back when tension is removed.
                    I recently did this with the H frame on my ML7 countershaft that was twisted a lot. Came back nice and straight with no cracks.
                    #342682
                    Les Wilder
                      @leswilder20052
                      What a pleasant surprise!
                      The immediate responses from friendly and knowledgeable members are greatly appreciated. I will certainly try to straighten the aluminum casting, but I have to say that the built-up items that JasonB showed look better than what I expect my casting would look like, even if I can get it perfectly flat. Does JB Weld hold well to aluminum? Do you try to remove the resulting fillets, or is the epoxied base a hidden part? One further question – are the raised bosses on the casting necessary for engine function, or are they there to allow for machining to get a level plane for the components. If I use flat plate for a built-up base, I'd just as soon leave them off.
                      I may try to find the recommended annealing temperature, and set and use the kitchen oven and let the part soak for a while at that temperature. Will let everyone know the result.
                      I think I have located the relevant back issues of ME at a public library, and if so, see if they contain detailed parts drawings before ordering the Reeves set. Does anyone know if the Brunell "construction notes" are useful?
                      Sorry for all the "newbie" questions, but I want to do this right!
                      Now I'll post to the proper forum for thoughts as to whether to continue to look for a screwcutting lathe to replace my hand-operated carriage lathe, as I presume smoother cuts will result with powered feeds.
                      Thanks again!
                      Les W.
                      #342689
                        Les the JBWeld will hold to clean aluminium though the joint is a bit weaker than on steel but plenty strong enough for this use. As most castings tend to have fillets in all the internal corners the JB Weld that gets squeezed out can be shaped into a fillet as it starts to firm up or filed with a round needle file when dry.
                        The raised areas were used on the full size castings as it reduced the amount of metal that needed to be machined flat but for our purposes could be left off.
                        If you do decide to make your own there is some more detail on how I went about the ones shown above starting  here and here
                        I think the Brunell notes are just going to be photocopies of the ME article, have sent you a message click the envelope icon in the green bar at the top of the page.
                        J
                        Edited By JasonB on 22/02/2018 07:32:32
                        Edited By JasonB on 22/02/2018 08:06:44
                        #342717
                        Ian S C
                          @iansc
                          For your temperature control use the soap as suggested by Neil and Hopper. Had a friend who was rebuilding Hiller Helicopters, and he used that method when forming compound curved skins, this method approved by Hiller, and the FAA.
                          Ian S C
                          #342728
                          Hopper
                            @hopper
                            Posted by Ian S C on 22/02/2018 10:08:19:
                            Ian S C
                            That's where I learned the soap trick from – a mate who is an aircraft engineer and served his time doing aluminium bodywork on old DC3s etc.
                            #342737
                            richardandtracy
                              @richardandtracy
                              Agree about heating. The most commonly used aluminium casting material 45 years ago for this type of little casting was LM4 to BS 1490. It has about 1% strain to failure, so is a very brittle material, and if the casting has the curvature you suggest, it'll fracture long before deforming enough.
                              Another fun idea might be to cast your own. It isn't all that hard to do with aluminium & can be done very cheaply. I was inspired to do my own casting by a fellow countryman of yours: **LINK**
                              I ended up with a tiny furnace that I wrote up here: **LINK** The article is quite old, but I last used it 21 days ago, and the concrete lining is just about shot after 15 years or so.
                              Richard.
                              #342773
                                Posted by Hopper on 22/02/2018 12:05:42:
                                Ian S C
                                I learned it from the Ladybird Book of Metalworking – seriously!
                                Ian S C
                                  @iansc
                                  To retain the old casting, it might be better to put a number of hacksaw cuts up the sides of the base, then heat and bend and fill the gaps with JB Weld or similar filler, you still might end up with a fabrication, or some pattern making and getting a casting done. If your mad enough, you could carve it out of a block of aluminium. good luck Les.
                                  Ian S C
                                  #342902
                                  Maurice Cox 1
                                    @mauricecox1
                                    Hi Les. When I built my ME beam engine, it had a bowed bed plate. It was iron. I was able to use it as it was, but you could see the thinning of the flange in the centre. I have joined this thread as you mention the missing gear. When I made my engine, I found that using gears of the size specified, there was insufficient clearance between the lay shaft and cotter remaining the big end. I overcame this by increasing the tooth count by five on each gear.
                                    Maurice
                                    #342904
                                    Hopper
                                      @hopper
                                      Posted by Neil Wyatt on 22/02/2018 17:39:39:
                                      Ian S C
                                      Now there's a blast from the past. I think that's where I learned most of what I know about electrickery from.
                                      #342906
                                      KWIL
                                        @kwil
                                        Always anneal Ali rivets with the soap trick before use (aviation work again)
                                        #342921
                                        Roderick Jenkins
                                          @roderickjenkins93242
                                          Posted by Hopper on 23/02/2018 11:15:19:
                                          When I started my undergraduate physics course the Ladybird book of computers was on the book list.
                                          Rod
                                          #342927
                                            The second project we had to make in my first year of metalwork at school was a round ashtray flanged from ali and we were shown the soap method. Think the subject matter may be a bit more PC these days!
                                            #342929
                                            Mike Poole
                                              @mikepoole82104
                                              Ladybird have some very useful titles.
                                              #342931
                                                Posted by Roderick Jenkins on 23/02/2018 12:14:53:
                                                Rod
                                                Both of those are at my dad's house. The computer one is entertaining at the very least!
                                                #342937
                                                Martin Kyte
                                                  @martinkyte99762
                                                  The soap trick reminds me of the temperature indicator for aluminium sheet when annealing with oxy/acetelene torch. Turn the acetelene up and coat the sheet with a thin even layer of soot. Neutralise the flame and warm the sheet up so the soot just burns off evenly all over. I have to confess to not having done it only seen it but no doubt others will have.
                                                  regards Martin
                                                  #359594
                                                  Les Wilder
                                                    @leswilder20052
                                                    Hello all!
                                                    After some travel, computer upgrades, problems and resolutions, I am finally able to post in followup to February's posts. First of all, I want to thank everyone for their suggestions and help regarding the bowed aluminum bedplate.
                                                    It's now perfectly flat!
                                                    I was able to contact a technical rep at the Aluminum Association here in the US, who suggested annealing to 650 degrees F, then allowing air cooling (no rapid quenching), and bending while still somewhat warm. Not having a large torch, and not sure of my ability to uniformly heat the piece with both thick and thin sections, I saw that our outdoor barbecue had a temperature gauge that went up to 600 degrees, so I waited for a warm day (80 degrees) and using a thermocouple temperature probe, was able to get the internal temperature up to 650. Held it there for about 40 minutes, put it on a flat plate, with packing under the convex side and found it easy to bend.
                                                    Very different from the bit of flash that cracked off like glass when I first tried to see how ductile the casting was!
                                                    Now on to the column!
                                                    Thanks again to all. Les
                                                    #359652
                                                      Well done Les,
                                                      Useful information,
