Posted by Andrew Tinsley on 22/07/2022 18:51:33:
I have recently noticed a plethora of adverts for the above. The rods originate from China. The aluminium rod has a central core of flux.
The melting point is quoted as 320 Centigrade in some adverts and up to 690 Centigrade in others! I suspect the Chinese are getting their Centigrade and Fahrenheit mixed up or they are not temperature savvy people!
Welding rods they are certainly not. They seem to be a step improvement of the longstanding "aluminium" rods that need a stainless steel scraper that scratches the oxide from the aluminium to be soldered.
They claim to "weld" copper and even steel, they also claim an intermix of the material to be welded and the aluminium rod, sounds dubious to me.
The soldering rods work for me, but it is an awkward three handed job. Anyone tried these rods? , If not I will get some on order to try them out.
Andrew.
Not sure what you're looking at Andrew. There are lots of variants on sale ranging from high temperature products mostly made of Aluminium down through various alloys, with or without flux, to solders containing no Aluminium at all. Some are Tig, others work with a torch, and the low temperature type should work with an ordinary soldering iron. What they are for, and how they are used, is in the small-print.
Which particular rods are you thinking of buying and how do you intend to use them?
