myford leadscrew
myford leadscrew
Home › Forums › General Questions › myford leadscrew
  • #404240
    Philip Burley
      @philipburley44197
      When I have tried to use the hand wheel on the end of the lead screw on my aged S7to move the cross slide with the half nuts engaged . it's always difficult to move because it turns the screwcutting gear box as well . Just been cleaning and oiling , and I cant see any way of disconnecting it . I never use it for that reason . Is this the normal situation or am I doing something wrong ? Just what is the use of that graduated hand wheel ?
      Regards Phil
      #26542
      Philip Burley
        @philipburley44197
        #404247
        John Haine
          @johnhaine32865
          On a lathe without gearbox you just remove the gear that meshes with the one on the end of the leadscrew. Presumably not so easy if you do have a gearbox.
          #404253
          T.B
            @t-b-2
            If you move the selector lever on the top of the gear box and leave it between two normal settings this will disengage the gearbox gear train and the leadscrew should be free to turn with the handwheel , a bit like a car in neutral !
            #404269
            Hopper
              @hopper
              There have been drawings over the years for a dog clutch — to bring it up to the standard of a Drummond M type. 😁
              #404294
              Brian Wood
                @brianwood45127
                Philip,
                An alternative to T.B's suggestion is to pick the gap in the selector positions on the front of the gearbox and leave it parked there instead.
                #404296
                Phil H1
                  @philh196021
                  As T.B says, just disengage the gearbox using the selector arm and the leadscrew will rotate freely. The graduated handwheel is invaluable for measuring turned lengths. I use it all the time.
                  #404365
                  Philip Burley
                    @philipburley44197
                    why didn.t I try that before !!
                    #404368
                    Howard Lewis
                      @howardlewis46836
                      Also, if the Handwheel is tight up against the Tailstock end bearing, it will make turning the Handle hard. You only need just enough clearance to allow it to turn, with minimal endfloat on the leadscrew.
                      #404373
                      Jon Lawes
                        @jonlawes51698
                        I find the handwheel on my lathe annoying (ML7) as the graduations don't go up cleanly in tens for each revolution. I can't explain it very well, but I mean the end of the graduations end in a five when it reaches zero.
                        I know what I mean if no-one else does…
                        #404387
                        Dennis Pataki
                          @dennispataki22631
                          If it's fitted with an 8 TPI lead screw, and I expect it is, the graduated hand wheel will need 125 divisions for each division to show .001" of carriage travel.
                          So, yes, the last division before the zero would be a five.
                          #404389
                          Mike Poole
                            @mikepoole82104
                            Posted by Jon Lawes on 09/04/2019 20:06:03:
                            As the lead screw is 8tpi you are rather stuck with it moving 125 thou per revolution but you could have a metric version and move 3.175mm, both make life awkward if you have to count past the zero point. Such is life.
